Projects "Coal Bin" 1930 Model A roadster
Discussion in 'The Hokey Ass Message Board' started by Hurley50, May 3, 2013.
  1. brady1929
    brady1929
  2. Tnomoldw
    Tnomoldw
    :)Keep up the good work ,:cool::D
  3. Hurley50
    Hurley50
    from NC
    Firewall all welded up and epoxy primed.
    kidcampbell71 likes this.
  4. Hurley50
    Hurley50
    from NC
    Another thing I did was extend the hood because it is on a 32 frame. I moved the grill/radiator back 1" so I had about 1.5" to fill. I'm also going to use hood sides so those get extended too. I used the full ht on the hood side (because it is channeled a little), I will just welded the hinge tubes up higher, then I will cut off the excess on the hood top.. see the 3rd picture.. the blue tape is what will be cut off.
  5. Hurley50
    Hurley50
    from NC
    I wanted to lean the windshield back, so I cut a V cut on the bottom uprights. I still need to make a brace behind it to attach the screw...
  6. Hurley50
    Hurley50
    from NC
    Got the brake pedal ***embly tacked in place so now the body is ready to come off the frame. Going to do the welding on the underside of the body and finish the body work. In the meantime the ch***is will be powder coated gloss black after a few tweaks to that.
  7. Shaun1162
    Shaun1162
    Wow, this roadster is really coming along! Going to look real sharp when it's all black... Especially with those wheels.
  8. Hurley50
    Hurley50
    from NC
    Thanks Man! I hope to have it on the road by September...
  9. Muggy
    Muggy
    from England
    This is a one sweet roadster. I was just wondering what colour are you going to paint it if any? The original green?
  10. Tnomoldw
    Tnomoldw
    :)Very good stuff here !:cool::D
  11. Hurley50
    Hurley50
    from NC
    Actually when taking the paint off the original color was a dark blue, but it will eventually be all gloss black. I might run the body in black primer for a little while...
  12. olskoolrodder
    olskoolrodder
    Looking great! Keep posting pics
  13. Hurley50
    Hurley50
    from NC
    The ch***is is now powder coated gloss black. The front frame horns are now boxed. As you can see my boys think it looks pretty cool. I'm having the ch***is all put together by a professional while I get the body ready. As you can see I was working on the door overlap gap. I just cut the door jam and made it meet the door... much better... I didn't take a good before picture, but it was about 1/4" gap in the center of the door. Hopefully get the rest of the body in primer in the next few weeks.
  14. jeepers00creepers
    jeepers00creepers
    Looking sweet!!! Keep up the good work!
  15. Hurley50
    Hurley50
    from NC
    Most of the floor welded in. I'm waiting on the front floor until I cut the master cyl hole (it's just cleco'ed in for now). The trunk floor has to wait until I get it back on the ch***is, the coil over mounts are above the floor line. My first try at bead rolling the "X"... didn't turn out too bad, not perfect... never see it under the seat anyway.
  16. Tnomoldw
    Tnomoldw
    :)Very Good! :cool:Keep it going:D
  17. Hurley50
    Hurley50
    from NC
    Exhaust done... I might modify a few things down the road, I still need to add the dumps out the side. Put the body back on the frame again to cut the brake pedal hole, master cyl hole and make the trans tunnel.
  18. gnichols
    gnichols
    from Tampa, FL
    Nice job. Love those windshield posts. Subd. Gary
  19. Hurley50
    Hurley50
    from NC
    The body is back off the frame, finished welding on the bottom side of the floor. I primed, seam sealed and painted the underside.
  20. NoSurf
    NoSurf
    Incredible job. Looks great!
  21. irace2win41
    irace2win41
    Nice build. I guess we need an NC roadster club!!!!
    Rod
    Studebakermatt likes this.
  22. 54Buick48D
    54Buick48D
    from Maryland
    Really looking nice and coming together!
  23. Hurley50
    Hurley50
    from NC
    Thanks!
    Thanks! I'm looking forward to having less parts boxes in my garage!
  24. jim henderson
    jim henderson
  25. brady1929
    brady1929
  26. Hurley50
    Hurley50
    from NC
    Put a few coats of filler primer, here is a before and after... I have it all blocked down, need to fix a few spots then satin black. I don't have the patience to do gloss black yet... need to get this baby on the road! I already painted the firewall gloss black and the interior satin black.
  27. FlynBrian
    FlynBrian
    Very nice work. I like it a lot!
  28. TrampHammer
    TrampHammer
    Sweet find and build. I'm 34 and I've got a 29 roadster project and a little boy on the way.
  29. kasultana
    kasultana
    Great work keep it up. My 29 is about a month away from being on the road in Davidson.
