Jeep TJ springs under a '64 C10
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, May 30, 2013.
  1. need louvers ?
    need louvers ?
    Hi gang,
    I just spent some time crawling around under "endlessearth's" new '64 longbed yesterday and found it to be a pretty solid old truck. But, one of the things we do need to adress is rear springs. I know several companies offer drop springs for these trucks, but I have read here and several other places about using Jeep TJ springs. Anybody have any real world input about ride and carrying capacity using these springs? Anything would help...
  2. VNTGE41
    VNTGE41
    from l.a.
    Tj springs bolt right in but man they are super soft. They give about a 4 inch drop but you wont be able to carry much in the bed. I took them out . Super soft ride no load capacity
  3. need louvers ?
    need louvers ?
    Thanks VNTGE41, that is what I was wanting (or not) to hear. he intends to put some hay in the back of this from time to time for his wife's horse.
    Any body else have a similar or better experience?
  4. Hnstray
    Hnstray
    from Quincy, IL
    Chip,
    you might want to explore first generation Grand Cherokee coils. Basically same setup but designed for a bit heavier loads.
    Ray
  5. slammed
    slammed
  6. supervert
    supervert
    tj springs are like 125lbs , maybe some zj's would be a little better i have a chart on pirate4x4 that i can post up.
  7. supervert
    supervert
  8. hoop98
    hoop98
    from Texas
    Here are some specs from Moog on some springs. The CC means Variable rate, they have a soft range then get stiffer.
    The installed height for each was calculated with the C10 load.
  9. Pete
    Pete
    Id be careful here, those springs are not super hard core rockabilly traditional! lol
  10. Dane
    Dane
    from Soquel, CA
    You could put the TJ springs in and some load leveler air bags and tune the ride for what ever is in the back.
  11. VNTGE41
    VNTGE41
    from l.a.
    I think i remember reading that chevelle rear springs work too. I just cut my stock ones for now and made 2 inch blocks
  12. VNTGE41
    VNTGE41
    from l.a.
    The ride is soo much better and ive thrown a few motors in the bed and it rides fine.
  13. peter schmidt
    peter schmidt
    from maryland
    If you do the chevelle do 70-72 the earlier ones were taller i had a set of both or just make up some 2 or 3 inch blocks i have a set of longer u bolts i had made up for my old burban i didnt use and a bolt in notch if you want to go real low ill let em go cheap if you want them.
  14. oakmckinley
    oakmckinley
    Hey now it's the best of both worlds, were talkin JEEPS on the hamb.
    I love Jeeps.....:D
  15. Ran TJ coils and Airlift bags to control the softness in a friend's '64 C10. Dropped down a good 4" and the bags with 5-10psi kept it firm enough for daily driving. Bumped up the pressure to carry anything over a couple hundred pounds in the bed.
    Sent from my DROID device using the TJJ mobile app
  16. need louvers ?
    need louvers ?
    Thanks guys! I hadn't thought about airlift bags, I guess this deal is kinda why they were created all those years ago.
  17. GreenMtnBoy
    GreenMtnBoy
    As said above the TJ springs are about a 4" drop and soft. The main benefit is they are available FREE as takeouts from most 4x4 shops. I like the softer ride and just throw the stock springs back in for any major hauling. The airbags would also work well.
  18. mphudak
    mphudak
    from Atlanta
    Tj Rubicon hardtop/automatic or lj (unlimited) in any configuration (rubi auto hardtop would be best) for tj/lj springs with a little more weight capacity.
  19. need louvers ?
    need louvers ?
    Hey gang,
    Had to bump this up again as I got to slide under this truck today and start doing some measuring. Doing some more searches on this stuff I'm seeing notes of TJ, FJ, LJ, ZJ, etc. I guess part of the problem is - I don't speak Jeep! I wouldn't know what an FJ Jeep product was if it ran over me. Must come from a life led driving everything 3" off the ground... Someone above suggested Grand Cherokee first gen, would that by nature be a heavier spring? And what year range would be considered first gen? And what would it's "J" designation be? And, last but not least, are all of the Jeep springs the same double pigtail design that will basically drop into the C10 application so I can just sit to my book and look at installed heights? Sorry for the batch of questions, but my spring book doesn't have the various "J" demarcations for these products, and a bit confused.
    Last little request for you guys running Jeep rear springs under C10s - If you have minute or two under your truck this weekend, can you Measure the installed height of your springs and note what model designation they are from? I think this could be a valuable resource to anybody down the line that might end up trying to do this stuff blind like me.
    Ask me damn near anything about a '09 - '48 Ford and I can probably rattle off two ways of doing it and the part numbers to get it done, but these things are a whole different ball park for me.
    Thanks gang, Chip
  20. Checksix!
    Checksix!
    the dropped springs they all sell are 80's monte carlo springs. SS models had a higher spring rate, hope that helps.
    Dave
  21. GreenMtnBoy
    GreenMtnBoy
    Ha ha..."it's a jeep thing..." OR better yet..."it's a hotrod thing, you wouldn't understand."
    TJ=97-06 Wrangler...very plentiful stock takeouts from lifts.
    ZJ=93-98 Grand Cherokee
  22. falcongeorge
    falcongeorge
    from BC
    Chip, heres Hamber "Sir"s C10. maybe you should send him a pm. This thing really sits good, IMO. And yes, I know those are TTO's.:rolleyes: I love this truck, really good color choice too.
