I am having issues with my Ignition and Starter wiring. How do I hook it up?
Discussion in 'The Hokey Ass Message Board' started by mookiex4, Jun 8, 2013.
  1. mookiex4
    mookiex4
    from Reno, NV
    OK Guys.
    This is my issue; I picked up my 1965 GMC and had it towed home. It has been at the local High School as a cl*** project. They installed a late 60's 283 that was rebuilt to 327.
    They have everything done with the exception of the wiring that runs from the ignition to the Battery, Alternator, Voltage Regulator, over to the coil, (If it does that.) and down to the starter.
    They disconnected all of the wiring that was on the old 305 V6 and it is still there but I am not sure what I have to do in order to properly hook it all up. Can I use the stuff from the old V6 or do I start form scratch? I am kind of at a loss. I can do wiring, but am not sure of myself when dealing with a harness of wires that run in all different directions. It may be easier than it looks but it seems a bit overwhelming.
    Is there any way to get a decent diagram? I cannot find anything online and a Chiltons from that era is tough to get.
    Thanks much for any help that you all can provide.
    Mark:confused:
  2. tfeverfred
    tfeverfred
    Will this help?
  3. tfeverfred
    tfeverfred
  4. joeycarpunk
    joeycarpunk
    from MN,USA
  5. mookiex4
    mookiex4
    from Reno, NV
    Yes it is somewhat helpful and informative. It is lacking the starter and coil, but I think I can use this and some other things to try and get it worked out.
    Thanks,
    Mark
  6. mookiex4
    mookiex4
    from Reno, NV
    Cool. The link is quite helpful. Now I have to either get up early in the morning or sweat it out in the sun. Thanks Guys.
  7. mookiex4
    mookiex4
    from Reno, NV
    The only difference would be that the alternator is a 4 wire alternator not a one wire.
