whats the hole for side of cowl an 30 Mod. A?
Discussion in 'The Hokey Ass Message Board' started by bigvinny, Jun 9, 2013.
  1. bigvinny
    bigvinny
    do you guys fill this hole? what was it for?
  2. tfeverfred
    tfeverfred
  3. HOTRODPRIMER
    HOTRODPRIMER
    What hole?,,,I don't see one. HRP
  4. tfeverfred
    tfeverfred
    It's right THERE!
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    Cowl lights went there. Cut a round piece of 18 ga the same size as the hole, tack it in place, then finish welding up all around it and metal finish it.
    It helps to drill a small hole in the center of the piece of 18 ga so it ends up looking like a fender washer, then you can put a small bolt and some nuts on it to use as a handle to hold in in place while you do the tacking. Then you remove the bolt and weld up that hole too.
    When you are done this is what it looks like. (the second hole was for cowl steering the car had at one time)
    Don
  6. HOTRODPRIMER
    HOTRODPRIMER
    Oh,,that hole!:rolleyes: HRP
  7. TagMan
    TagMan
    I know.......it's the A-hole !! :D
  8. roseville carl
    roseville carl
    <!-- / message --><!-- sig -->__________________
    now thats funny right there.........
  9. joeyesmen
    joeyesmen
    I don't get why everyone removes them . . . I think they look good.
  10. 5window
    5window
    There's also a hole, possibly, at the end of the bead where the attachment rods fro the cowl band goes through-a couple of inches up from the bottom of the cowl.
  11. 5window
    5window
    I like them too, but that's a tall,thin car. Maybe it;'s the camera angle?
  12. st.rod
    st.rod
    Just put a magnet behind the patch piece to hold in place when you tack.
    Larry
  13. joeyesmen
    joeyesmen
    Here's a side view:
  14. 3wLarry
    3wLarry
    from Owasso, Ok
    4.50's and 7.50's?
    kidcampbell71 likes this.
  15. joeyesmen
    joeyesmen
    1935 Ford wheels. Front are 560 x 16 Firestones, rear are 750 x 16 Firestones.
  16. 5window
    5window
    Thanks
    :D
  17. Fenders
    Fenders
    When you see a hole, you are tempted to fill it. :D
  18. need louvers ?
    need louvers ?
    ...'Cause unless the rest of the car is festooned with every trinket Ford hung on it, cowl lights look like ***...
  19. Model T1
    Model T1
    I thought the reason we bought old cars was because they look different. I like cowl lights.
  20. 5window
    5window
    I like cowl lights, too. OTOH, I 'm not crazy about non-functional, decorative louvers! I'm fine with one that are there for a reason. But,whatever floats your boat is ok by me.
