hard water spots on alum wheels...removal?
Discussion in 'The Hokey Ass Message Board' started by boogeracng, Jun 9, 2013.
  1. boogeracng
    boogeracng
    from Eureka,MO
    Anyone have a method for removing water spots from polished aluminum wheels (Real Rodders Wheels). I've tried all the usual.....aluminum polish from several sources.....Mothers, Flitz, etc, polishing compound, Simple Green, vinegar and water. Nothing seems to totally remove them. Suggestions?
  2. HOTRODPRIMER
    HOTRODPRIMER
    Have you tried a baking soda and water paste? HRP
  3. themoose
    themoose
  4. shotrod
    shotrod
    You might have to use acid to reclean the aluminum then repolish,I have to do that to my semi wheels once a year,the best polish I've found is white diamond it works killer with minimal work
  5. voodoo1
    voodoo1
    Where do you find the White Diamond? Mike
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Sure they arent coated?
  7. Tio Geo
    Tio Geo
    vinegar and dish soap
  8. AZ 54 BELAIR GUY
    AZ 54 BELAIR GUY
    from AZ
    The best thing I've came across is take the white bars they use for polishing aluminum and use a bondo cheese greater and shreed the white bar and mix it with gasoline and make a paste with the two. And rub it in and wipe it clear with a clean cloth and it works great. Trust me it works!
  9. Rocky
    Rocky
    Classified Editor
    Vinegar works great on gl***...might have to re-polish aluminum after using it.
  10. khead47
    khead47
    Zephyr Pro 40. Expensive, but easy to use. Use it on my canned ham.
  11. RDAH
    RDAH
    from NL, WI
    White Diamond is at pretty much all truck stops.
  12. go-twichy
    go-twichy
    I've had good luck with a product called "wicked". trucker friend showed it to me.
  13. Normbc9
    Normbc9
    I use WENOL in a tube purchased from Ace Hardware. No abrasives and I also use it to clear scratched of auto window gl***. It odes best with all cotton Turkish towels as the buffing material.
    Notmbc9
