fenderwell headers
Discussion in 'The Hokey Ass Message Board' started by old buzz, Jun 9, 2013.
  1. old buzz
    old buzz
    from middle tn
    does anyone know if anyone makes fenderwell headers for an Anglia with a sbc?
  2. Jtg-3
    Jtg-3
    from Huron Ohio
    Hi Gent
    I'm doing a Henry J , and found headers for a chevy v8/toyota land cruiser conversion (google it) there is a company that markets them both plain or chrome (something adapt) the collectors dump about 3 " behind rear of block almost @ crank centerline I'll attach 2/3 pics these may help Regards JT
  3. willys41
    willys41
    Try Stahl headers York Pa.
  4. plodge55aqua
    plodge55aqua
    from Alberta
    Great info... My question.. do these clear the Original Body mounts? also the front tire size on yours what is it?
  5. David Walter
    David Walter
    from Troy,Al
    When I was running SB Chevy's years ago, I used 55 to 57 Chevy style fender-well headers, the pipes all went towards the middle like block hugger headers except strait out then about a 45 degree turn down, worked well in a 38 Ford and other cars. David.
  6. 1971BB427
    1971BB427
    from Oregon
    Not a Anglia, but very similar. My Austin with 327 SBC is running Patriot Fat Fender Chevy headers. They sit right in my lower fender drops, and work well. Whether they'll work for your Anglia depends on where your engine sits. Mine's back pretty far, but the distributor is just under the cowl.
  7. Check out some pictures of up-sweep dragster headers. I used them up-side down on my car. There is a picture here . Check out '40 Ford F.E. thread. Gene.
  8. plodge55aqua
    plodge55aqua
    from Alberta
    I just bought a set... a Month later.. finally got.. I will have to set the engine back quite far.. so the Dumps clear the tires.. a 1/2 inch on the p*** side. 3 inch clearance on the drivers when wheels are straight. ****.. 500.00 later.. and will have to move the firewall back... Not looking forward to this.
  9. Larry T
    Larry T
    There are so many ways to mount the engine, I don't see how anyone could guarantee their headers would fit.
    As an example my engine is 19" crank centerline in front and the transmission tailshaft is 16". Engine is offset 1" to the right of centerline. I couldn't find any to fit, so I built some. Now I decided to drop the engine some, so I've got to start all over.
  10. plodge55aqua
    plodge55aqua
    from Alberta
    Ill take this a a live and learn.. I know S#@t happens..:)
  11. swade41
    swade41
    from Buffalo,NY
  12. bulletproof1
    bulletproof1
    from tulsa okla
    yeah but what about a big block?
  13. 1971BB427
    1971BB427
    from Oregon
    If you have a BBC powered Anglia you might try the Speedway BBC Tri 5 fenderwell headers for $219. Even if you had to rework them a little, the starting price is so cheap they're worth it. I'd guess they'll be a tad too wide, and need narrowing to fit an Anglia.
  14. swade41
    swade41
    from Buffalo,NY
    If this helps for the big block question, a couple pictures to see how the tubes lay out on those Speedway ones.
