Found a motor that was rebuilt and sitting for a long time. Problems?
Discussion in 'The Hokey Ass Message Board' started by iroc409, Jun 10, 2013.
  1. iroc409
    iroc409
    I found an inline 6 I’m interested in, that has been rebuilt. However, it was rebuilt in 1988 and it’s never been fired up. The guy took the head off to inspect it, and it had a tiny bit of surface rust in the bores he cleaned off with an emory cloth. He has all the paperwork with it from the rebuild—a shop did all the work.
    The interesting part is, the person he got the motor from went and had all the tin on the motor re-chromed at the same time (he has the paperwork for that as well). All the covers, motor mount, oil filter canister, fan, pulleys, vent tube, air cleaner—pretty much everything, and it looks nice. I don't know anyone that makes chrome parts for these. I was planning on going for an original look, but the chrome would be very unique and make a cool hot rod.
    He’s asking $2500 for all of it, and it would probably cost about $3500 to rebuild one. What kind of problems should I be concerned about from it sitting? It was painted, and I don’t see anything in the pictures to worry about. It will need a few gaskets to put it back together, but otherwise is a “fresh” motor.
    <!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:DoNotPromoteQF/> <w:LidThemeOther>EN-GB</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <w:EnableOpenTypeKerning/> <w:DontFlipMirrorIndents/> <w:OverrideTableStyleHps/> </w:Compatibility> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="&#45;-"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDo***ent> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="***le"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Sub***le"/> <w:LsdException Locked="false" Priority="22" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" SemiHidden="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> <w:LsdException Locked="false" Priority="1" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 1"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> <w:LsdException Locked="false" Priority="34" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> <w:LsdException Locked="false" Priority="29" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Quote"/> <w:LsdException Locked="false" Priority="30" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 2"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 3"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 4"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 5"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 6"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> <w:LsdException Locked="false" Priority="19" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> <w:LsdException Locked="false" Priority="21" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> <w:LsdException Locked="false" Priority="31" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> <w:LsdException Locked="false" Priority="32" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> <w:LsdException Locked="false" Priority="33" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Book ***le"/> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; text-align:justify; line-height:115%; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-ansi-language:EN-GB;} </style> <![endif]-->
  2. Deuces
    Deuces
    Prime the oil pump before starting it up....
    With fresh oil in the pan!!!
  3. junk yard kid
    junk yard kid
    Id probably put more cam lube on the cam before i fired it. But yah, give it a cleaning.
  4. Ebbsspeed
    Ebbsspeed
    What kind of precautions did he take to keep grit from the emery cloth from falling into the bores when he cleaned the rust off the cylinder walls?
  5. Saxman
    Saxman
    That was my first thought too.
  6. metalman
    metalman
    Since you need a gasket set anyway I'd take it apart, make sure it's clean, everything is rust free. I'd replace all the seals. I'd be worried about the seals being dry/ hard after that long. A leaky new motor wouldn't be cool. Even if you didn't feel compentent doing it yourself a machine shop probably wouldn't charge that much. A local guy here bought an old hemi that was sitting for ??? and a shop here charged him $250 to do just that. Cheap insurance on a $2500 investment.
  7. Fenders
    Fenders
    Rebuilt 25 years go, never run, and cylinders de-rusted with emery cloth?
    Oh wait, it looks nice.....
    Somewhere under $1,000 I'd be thinking.
  8. 31Dodger
    31Dodger
    Take it apart and clean it up as best you can. You will be glad you did.
  9. Model T1
    Model T1
    The biggest problem I see here is no one mentioned what kind of engine or what year. **** the **** out of the bores, add some Miricle Oil or WD-40, oil and prelube, put it back together,start it up and enjoy it in your ?????;) Chevy?
  10. iroc409
    iroc409
    Probably none. The head is still off the motor.
    That's a far cry from $2500, but part of the price is probably all the chrome goodies.
    So basically, I'm still going to have to take it considerably apart, and replace a lot of "stuff", and without removing everything (crank, etc) I'd still have a questionable motor (after probably having to drive 4.5 hrs to meet him).
    Maybe he'd just sell all the chrome stuff--not that I really NEED it, that stuff is probably hard to keep clean in an engine bay.
  11. iroc409
    iroc409
    International SD-220.
  12. Dane
    Dane
    from Soquel, CA
    I bought a Chevy 235 rebuilt and then sat in the guys garage for $500
    $2500 is way too much.
  13. czuch
    czuch
    from vail az
    You could 350/350 it for half that and get parts anywhere.
    If youre going for points, talk him way, way,way down. For that you could rebuild your motor too. Take it all apart and renew the pre lube on the mains and rods too.
  14. J scow
    J scow
    from Seattle
    Yup take it apart lube the cam and mains re-seal and go. $2500 seems high but if its what you want and you have the dough..... Try to talk him down I doubt there is a line of people waiting to pay that price for that motor. Offer $1500 and call back in a week or two.
  15. HOTRODPRIMER
    HOTRODPRIMER
    I think he has it priced too high. HRP
  16. iroc409
    iroc409
    The motor has been for sale for over a year. I wasn't planning on spending that at the moment, but want to get the truck running. We just bought our first house, so budget is definitely a concern.
    I've seriously considered the 350 route, but want to stick with a manual trans. It would be reliable, cheap and easy--but I would really kind of like to keep an original motor in it. The 350 is a tight fit near the firewall, it's better if it can be pushed forward a bit (but it fits without cutting sheet metal.
    I guess it's better driving it with a 350 than looking at it sit in the garage with the original motor.
  17. pdunn10
    pdunn10
    what year was the motor?
    I think he is searching for price he wants seems high.
    you can find a running 235 from a motor swap for about $500 if you look
  18. Big difference in a 235 and an International motor. I can throw a rock in any direction (almost) and find a 235. I wouldn't know where to start on the IH. Those things rotted out and went right to the s****yard around here.
    Part of the price is most certainly the chrome. Figure what the chrome parts are worth, what the engine kit is worth, and figure at a minimum needing to tear it down, clean it, and at best a new hone in the bores.
  19. big M
    big M
    If there is no longer any warranty on the machine work and ***embly, I certainly would try to get it cheaper. The work may have been good, or may not have.
    If you do buy it, be sure to lightly oil the cylinders, and rotate the crank to lube the pistons and rings. Most ***embly lube I have seen will last a good 20-30 years, but I'd still fill the sump and pre-lube everything by turning the oil pump with a speed wrench or drill until oil pressure is up.
    ---John
  20. Don's Hot Rods
    Don's Hot Rods
    from florida
    I would tear it down and replace the rings and gaskets, plus lube it all again. From sitting that long (25 years) the rings have probably lost their tension, as have the valve springs. The gaskets are probably dried out as are the seals on the crank and valve stems.
    I have a 394 Olds that I rebuilt about 7 or 8 years ago and am using it in my rpu project, it has never been fired. But I am going to totally dis***emble it and do the things I suggested above just because it is easier to do it now than after it is installed and running.
    And $2500 for a 6 cylinder seems like a lot of money to me.
    Don
  21. iroc409
    iroc409
    Motor kits from EGGE are about $2500 (about the only place I've found you can get a "kit"). Pistons can be had for around $450-600, but are the hardest. I talked to an engine shop run by an older gentleman in the PNW before we moved, and he said expect about $3500 for a long block build. Mine might need manifolds and a carb replaced. The head is probably shot.
    Parts are easier to come by than you'd think, and Rock Auto carries stuff now (even brake parts & MCs).
    I've found a few motors here and there, even a running one in Kansas for $150... but it was about a 6-hour drive. The guy has probably s****ped it by now. A few in the $5-600 range that haven't been rebuilt.
    There is TONS of chrome. Probably a couple grand by today's standards, but I've never chromed anything (just a few minutes of Googling) so it's a bit of a WAG.
  22. boutlaw
    boutlaw
    I purchased an overhauled SBF that had been sitting for 20 + years, never started. Could not rotate the engine. Pulled it apart and all the ***embly lube had turned to jelly/parafin looking goo. All bearings, rings, pistons, camshaft, etc were new parts. I don't know if a starter would have turned it over but if it had I feel sure the bearings, cylinder walls would have been damaged because of the goo in block and crank oil p***ages. I diss***embled it, cleaned the parts, lightly honed the cylinders and re***embled it using the same parts. It was a major pain in the ****, glad I got it cheap.
    BOutlaw
  23. iroc409
    iroc409
    Going with a V8 would be easier and I've been jonesing for a V8 again (it's been a while), but I would have to do some magic with the steering to get it in there. It will fit though, there's another guy online that rebuilt one of these and put in a MII up front and no sheetmetal appeared to be cut (for the motor--some was for the TH350).
  24. gas4blood
    gas4blood
    from Kansas
    As others have said, that seems like a high price for a 6 cyl. engine. Hard to find, perhaps so. But not very desirable, either. That's why he's had it for sale for a year. Half that money would be a lot after sitting for 25 years. Replace all gaskets and seals if you pull the trigger. Would it run? I'm sure it would. I also think it would leak, right away or in a little while. I agree with the others, a V8 would be cheaper.
    Comparison, sort of....I bought a 235 Chevy with several thousand miles on a rebuild, Offenhauser covers, headers, cam, full dual exhaust that came out of a '49 Chevy truck like mine. Also had a T5 trans conversion. Runs like a swiss watch. $750.
  25. The chrome is worth nothing if no-one is ever gonna see it.
  26. czuch
    czuch
    from vail az
    Go buy it. You're talking youself into it. Bro, you wont be happy with anything else.
    Chrome dazzle is killin ya. This one's 2.5 hrs away for 2500. The other one is 6 hrs away for 150. The just bought house and a 2500 rebuilt motor that needs to be totally gone through,,,,,,,,,,,youre in deep.
  27. iroc409
    iroc409
    Well, a bit dramatic, but the one for $150 is probably s****ped by now (haven't found the ad again), and was in very rough shape--but did run. I found one for $1200, that is of questionable rebuild, but it's too far for me to get. I'm going to have to do a lot of searching to get one to my door for less than $1000 that's any better than the one I already have, but I have time and you never know what you might run across.
    I have a free SBC if we can find it, but it needs to be rebuilt as well.
    I was thinking keeping the original motor with the chrome would be rather unique, but wasn't my original style intent.
    Unless he's willing to come off the price a lot, I'm going to p***. Too much work to get it running; I thought maybe there wouldn't be much involved. I've done a lot of car work, but never rebuilt a motor (yet).
  28. Call your local machine shop and ask what they want for a tear down, clean and re***emble with new gaskets and seals. Explain the senario to the shop. Maybe the shop that did it in 88 is still around? Back that $ off the 2500 and that's your absolute top dollar.
    Now if you feel comfortable doing the work all the better.
  29. So $2500 for a rebuilt motor that would cost $3500 to build plus the chrome too, it just needs to be torn down and cleaned thoroughly.
    Offer him $1500 or $2000 and see what happens. Sounds like it's not a bad deal - for that particular type of motor.
  30. stillrunners
    stillrunners
    from dallas
    chrome....won't get you...home.....like others offer less - cause it has been a hard sell...then like others said - go thru it.....
