47 Plymouth Special DeLuxe
Discussion in 'The Hokey Ass Message Board' started by flathead fred, Jun 9, 2013.
  1. flathead fred
    flathead fred
    So I about to pick up a 47 Plymouth Special Deluxe from a friend. Planning on a pretty straight ahead cl***ic bomb low-rider build. Looks lime parts are semi available. Anything unusual to tell about these cars. Still up in the air on motor and ****** combo. A bumb knee has me thinking automatic. No chevy small blocks thank you. What mopar fits in that skinny engine bay without a hell of a lot of effort??
  2. malcolm1943
    malcolm1943
    had a 47 for awhile, used a sbc and turbo 350. the engine bay isn't that skinny, you should be able to put whatever you want in it, might have to rework inner fenders a bit as I did when I put a MII in mine.
  3. GeezersP15
    GeezersP15
    from N.E. PA
    I put a SBC in mine, but have read about others, and seen a few with hemi's in them, so there's room for most anything you choose. And parts aren't that difficult to find. Skip over to the P15-D24 forum, and check that out. A lot of good info there, and forum members who are willing to help you out.
  4. Plymouth 318.
    A good engine and not tooo bad a fit.
    Saw a fellow from Illinois with a 318 in his coupe, and he was happy.
    If retaining the original steering system, the engine may need to locate
    about a couple inches to Right of center to clear. (I'm no expert....just
    p***ing on what I've heard.)
    There is also the P15-D24 Forum for 40s and 50s MoPars.....there are
    both stock and modified cars found there. Here's a link.............
    http://mopar.pairserver.com/p15d24ph_forum/index.php?/index/
    Just sign up and join in the fun.......lot of knowledge there as well as
    here.
  5. George
    George
    There's a bunch of Threads on putting a 318 into the 46-8s. As was said a slight move to the p***. side. You need the rear sump version from a Van or pick up, or the pan, oil pump pick up & dipstick from one. Fits in with only slight t******* of the inner fenders. drivers side ex man from the boxy Dart wraps around the steering column like it was made for it. Front shock relocation & disc kits. Be carefull about lowering the rear, can be a pian to get the wheel out between the drum & fender if you don't pay attention to room.
  6. daliant
    daliant
    I've got a 318 in my 46, you'll have to move some stuff around but it will fit.
    There's more pics on my build thread ▼▼▼
  7. BuiltFerComfort
    BuiltFerComfort
    Exhaust clearance by steering box is the main issue. Rack/pinion conversion or up-and-over manifold are options.
  8. flathead fred
    flathead fred
    Thanks for the info. I will check out the forum.
  9. 73RR
    73RR
