cleaning cast aluminum
Discussion in 'The Hokey Ass Message Board' started by vetteson, Jun 11, 2013.
  1. vetteson
    vetteson
    What is best way to clean cast aluminum (remove oxidation/stains)?
  2. Normal Norman
    Normal Norman
    from Goshen IN.
    Vettson, I usually use some kind of media blasting, sand, glass beads,etc. I don't care to use chemicals. Just personal preference. Normal Norman
  3. i use the mag wheel cleaner that's made for rough cast wheels, then run it through my dishwasher set on the pots/pan cycle.
  4. Willy301
    Willy301
    I usually scrub it with Dawn dish soap and water, and if that doesn't clean it, I hit it with a light acid solution for cleaning aluminum. That usually does it.
  5. 57 HEAP
    57 HEAP
    Heavy oxidation might require scotchbrite or sandpaper.
  6. mashed
    mashed
    from 4077th
  7. Dan1950
    Dan1950
    I took my aluminum intake to my local machine shop; where they glass bead blasted it.
    The thing came back looking brand new and it was a mess when I sent it in.
    Dan.
  8. Da' Bomb
    Da' Bomb
    For just light dirt and grease, Eagle 1 has a good product
    Pat
  9. Gotgas
    Gotgas
    from DFW USA
    I have a large tub that I use to clean my pool filters twice every year. I put a 4:1 tap water to muriatic acid bath in it and let them soak.
    I was about to dump the solution earlier this year but decided to put a couple of old intakes in it first to see what it would do. It took a while but it cleaned them pretty well. I noticed that any steel bolts were really giving off gas; I assume they were hydrogen bubbles. I will make sure only aluminum parts go in next time. I'll document my results better at the end of the summer when I clean the filters again. :D
  10. Saxman
    Saxman
    Eagle 1 aluminum wheel cleaner.
  11. 1971BB427
    1971BB427
    from Oregon
    I just cleaned up a pretty crusty tunnel ram intake. Spent hours with various polishes, and cleaners and some made things even worse! I finally used mag wheel cleaner, and a bristle brush, then just hosed it off with the garden hose. It worked fantastic!
  12. Blue One
    Blue One
    from Alberta
    Look up a product called Aluminum Jelly. Brush it on and then after a bit hose it off and the aluminum looks like new.
    Best stuff I have used. It would even clean off the red stain we used to get on our manifolds back in the days of red dyed leaded premium gas. :)
  13. tommy
    tommy
    before
    after bead blasting
    after powder coating
  14. snopeks garage
    snopeks garage
    from macomb MI
    I did the same it only coust me $30 too
