Carb adapter for a 97
Discussion in 'The Hokey Ass Message Board' started by hawkerdriver, Jun 7, 2013.
  1. hawkerdriver
    hawkerdriver
    I've got an old Edmunds manifold for duel carbs- 4 stud with 2 aero type strombergs. I want to run 2 97's. anyone knw where I can find 2 adapter plates?
  2. RichFox
    RichFox
    Maybe on your drill press?
  3. You can find this on evil-bay
  4. tommy
    tommy
    Speedway Motors
  5. Atwater Mike
    Atwater Mike
    X2! Start this project with some of 'you' in it. Good ingredients make the best salads.
  6. hawkerdriver
    hawkerdriver
    Got a link?
  7. kool32
    kool32
    from Kentucky
  8. tubman
    tubman
    What kind of engine are we talking about here? If it's anything medium to large, 2 97's won't be enought. I've had lots of luck using small base Rochester 2GC's on setups like this. Also, depending on the cir***stances, the 2GC's might be a lot cheaper than 97's (unless you already have them).
  9. hawkerdriver
    hawkerdriver
    346 Cadillac flathead. Currently running 2 stromberg aero types that have given me fits. Rebuilt them twice and still can't get them to run right. So I've opted to run 2 97's. don't have the 97's yet and I'm open to other ideas like the 2CG's.
  10. Bruce Lancaster
    Bruce Lancaster
    I think you are headed for too little carb with 97's or even 48's. You are about 100 cubes past happiness with 2 97's.
    An alternative would be the various Carter/Ball and Ball/Strombergs used on 318 Mopars...nice simple carbs.
  11. hawkerdriver
    hawkerdriver
    Would they fit the 4 bolt pattern of a Edmunds manifold?
  12. 5559
    5559
    from tn
    your not going to believe this but i'll throw it out here anyway-----------use a piece of hardwood!! Wood is the best insulator , i've done it in the past with 2bbl chevys with no problems. I've had one on my lawn mower for the past 3 years ----its a 16 hp that I could'nt fine a kit for-I put a bendix carb from a harley flh on it & it runs perfect on only the idle setting & will mow anything you can run over.
  13. Mike51Merc
    Mike51Merc
    Stromberg WW carbs will fit.
  14. oldestman
    oldestman
    I've always been happy with Stromberg WW's. Even more period correct, would be a pair of Holley 885's, used on Postwar Mercury and Lincoln flatheads. They're both 4 bolts that will fit. Air inlet is sidedraft and 3" diameter. A pair of Lincoln or Merc factory air cleaners powder coated to shiny aluminum or flat black would look awesome coming off the polished Edmunds.
    Art
  15. tubman
    tubman
    FYI, I have been working on putting a 2GC on my '51 ford using a Canadian aluminum Mercury manifold. I am going to do this the right way and bore out the Mercury manifold to fit the 2GC. Here are the throttle bore sizes I have found on these various carburetors:
    Holley 94 - 1 1/4 inches
    Merc manifold - 1 5/16 inches
    Small Base 2GC - 1 7/16 inches
    Doesn't look like much, but the 2GC comes out to be 30% larger in area than the 94. The Holley is in between, but closer to the 94. I don't know about the other carbs (carters, Strombergs), but I've had such good luck with 2GC's, I went with them.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'm with the guys that think a pair of 97s aren't going to hack it on a 346 cubic inch V8. There are several carburetors with the bolt pattern your intake's already drilled for. If you want the old look, a pair of Carter WCDs should fit the bill.
