56 Buick Special
Discussion in 'The Hokey Ass Message Board' started by Nickrodder, May 25, 2013.
  1. Nickrodder
    Nickrodder
    A couple of you guys out there wanted to see more pictures of my Buick, and I'm working on it this weekend so I thought I would take some pics. I bought a lowering kit and am in the process of installing it, 3" drop springs with a 30% stiffer spring rate. Here is the rear, still need to install the front kit.
  2. Nickrodder
    Nickrodder
    Here is the difference between the new and the old. Yup I'm 23 years old and this is way more fun then going out bar hopping and getting drunk.
  3. Rickybop
    Rickybop
    Nice lookin' Buick. Good job. You give us older guys hope for the future of the hobby.
    Be careful doin' the front springs. Have a nice weekend.
    Btw...Did Buick still use lever shocks in '56? If so, then I guess you don't have to worry about using shorter shocks. Even if it has tube shocks, due to the higher spring rate, you might not need to change 'em.
  4. 35desoto
    35desoto
    keep em pics rolling
  5. ROBERT JAM
    ROBERT JAM
    show us when you are finished---- love those buicks
  6. Nickrodder
    Nickrodder
    Well got the Buick lowered 3" over the weekend. Looks really nice and drives just like it did before , actually a little better because the original front springs were so worn out.
  7. Nickrodder
    Nickrodder
    Another cool pic
  8. Nickrodder
    Nickrodder
    No this Buick had normal shocks not never style shocks, the kit came with new shocks so I decided to put them in because the car was torn apart. And thanks for the comments, I know I'm a youngster and not a lot of people my age appreciate the cl***ics but I sure do!! And I'm having fun with this car!
  9. ROBERT JAM
    ROBERT JAM
  10. justinsr
    justinsr
    from Salem MI
    Where did you get the lowering kit from? I am working on a '57 Special and want about a 3" drop.
    Sweet looking ride!
  11. the-stig
    the-stig
    Nice looking Buick.
  12. Century
    Century
    Great looking Buick.
  13. robertsregal
    robertsregal
    She is a Beauty, and yes where did you get the lower springs? Would like to lower our 57.
  14. Nickrodder
    Nickrodder
    Thanks! And the kit came from jamcosuspension.com , some of their listings say different years for kits so the easiest thing to do is call them and tell them exactly what you want.
  15. justinsr
    justinsr
    from Salem MI
    Thanks! I think I will use them for mine.
  16. Dane
    Dane
    from Soquel, CA
    Nice work! You're gonna get way more/better good looking girls wanting to ride in your car than hanging out in bars. Especially at 23. You can do that when you're an old fart like the rest of us. :D
    Have you considered wide whites and spokes on the Buick? :cool:
  17. swissmike
    swissmike
    Now go out and get drunk and support the local economy. Leave the car at home, though...
    Great job!
  18. Brad54
    Brad54
    from Atl Ga
    I put a Jamco kit under my 54 Special and was very happy with ride quality.
    Your car looks great! stick or auto?
    I just developed heavier sway bars for these cars-- stock sway bar rate is 138lb/in, my bars are 500lb/inch. Should make going thru a corner a much nicer experience.
    -Brad
  19. Nickrodder
    Nickrodder
    Oh yes it needs wide whites! It's just the previous owner put brand new tires on the car so I'm going to use them for awhile haha. Haven't decided on wheels but cl***ic looking spokes wheels sound interesting. Haha I drive this car everywhere, it hold lots of groceries in the trunk haha.
  20. Nickrodder
    Nickrodder
    I like that body style of special! Sounds really cool, so you sell larger sway bars? I was thinking about putting a larger one on when I was underneath the car.
  21. Brad54
    Brad54
    from Atl Ga
    Yup. Just got the first boxed, shipped unit last week.
    I made a mistake in my numbers, too--the original sway bar is .69-inch diameter, and has a spring rate of 113lb/ft, not 138lb/ft like I originally wrote.
    My bar is 1.00-inch and 500lb/ft. I could have gone up to 1 1/8-inch, but that bumps the rate up to 800 lb/ft, which I felt was too stiff for these cars. Racing one through the corners, maybe, but not for getting groceries.
    The '56 Special came with a 322ci Nailhead, which is nice--the '54 and '55 came with a 264-inch Nailhead, and the weak 5-bolt cover manual trans (or Dynaflow). The '56, if it was a manual, has the beefier 6-bolt cover manual trans.
    You also have tube shocks and a rear crossmember for them, while the '54-'55 had knee-action rear shocks.
    Your front spindles are better too--they have a little caster built into them, whereas the '54-'55 are 0-degrees caster. The literature said it helped the car come out of corners easier.
    -Brad
  22. david_mark
    david_mark
    makes such a difference in appearance. I bet it rides alot better. Some wide whites will make this a completely different car.
  23. chstitans42
    chstitans42
    I agree, I am 24 and have a 1958 Chevy Bel-Air I wold rather work on as well
  24. Brad54
    Brad54
    from Atl Ga
    One thing about that Jamco suspension--you said you got the 3-inch drop. That's what I got too. We figured out the right kit when my buddy was sitting on the front fender, and it just looked spot-on perfect. We measured it, and it was 2-inches from the "stock" height.
    When I called Jamco to order the kit, they said "the old springs and body mounts have sagged an inch, so get the 3-inch kit, because it's 3-inches lower than stock, and you're already an inch lower than stock."
    Some of the most useful advise I've ever gotten.
    I had wide whites on the '54 too, and they really do help the look. But they ain't cheap! so get some life out of those treads!
    -Brad
  25. n.z.rodder
    n.z.rodder
    Awesum job Nick, I've always thought the rear wheel arch was too high on these Buicks, a little lowering goes a long way, I'd give my kids left nut for a '56 Caballero.
    Scotty
  26. Nickrodder
    Nickrodder
    Thanks for the comments, it does ride really nice and I agree it needs some wide whites. I will buy from jamco suspension again
  27. justinsr
    justinsr
    from Salem MI
    so...
    I have read some negative things on here about Jamco and I am ready to order springs today. It seems like you had a good experience with them.
    I would apreciate some feedback, How long it took to get your springs etc.
    Thanks
  28. nailheadroadster
    nailheadroadster
    Good looking 56 man. Congrats
  29. Nickrodder
    Nickrodder
    It took about 3 weeks to get everything, I know everybody says they have been having a bad experience with Jamco but I am telling you guys I absolutely love my Buick, I get so many compliments on it being lowered , People think that my car looks like a $12,000 car but I only paid 4 thousand for it!! I love it
  30. justinsr
    justinsr
    from Salem MI
    Do you have any before and after sideview pics you can post?
