Projects 1948 Chevrolet fleetmaster
Discussion in 'The Hokey Ass Message Board' started by gallogiro, Jun 9, 2013.
  1. gallogiro
    gallogiro
    paint arrived for the body im ready to paint. Flat buckskin tan for the body, flat black for the fenders and roof i pick up Thursday
    guess they have special products to detail flat/matte paint i guess
    good flat paint. you guys know that company eastwood? theyre excellent on theyre tools and products and i use them the most, but all the good paints i wanted to buy they don't sell or ship to California, so if you have theyre color chip chart might as well just throw it away if youre in California. but tcp global will even single stage og oil based they don't care.
  2. gallogiro
    gallogiro
    ok so I wanted the heads off to lube up the cylinders to get the flywheel to turn. I banged them out for 2 HOURS, only got them to move this much. thought man whatever they used to seal the head gasket I want to know what it is, it just wont release them!
    turns out I just missed this bolt
    heads off, now you see why the flywheel wouldn't turn
    heads off, heads are still good
    oiled the cylinders good, then slowly it started turning till I was able to get the last 2 bolts, then the clutch came off then the flywheel then the bell housing
    as for the other bell housing, all I needed was more leverage
    and its off
    you have to take the flywheel off to get the last 4 bolts to release the bell housing.
    cleaned it up
    before
    now
    now I can get back to paint and body. turns out the field next to my house theyre finally building a house. they better bring in a scientist with that clickity click machine to test the place, it has more oil in that ground than irak.
    I lit the dirt on fire once. you guys know what im talking about, not all of you recycle oil. if you bury something in that soil, it comes back to you, but its not the same..
  3. gallogiro
    gallogiro
    Pomona was kind to me today it didn't leave me feeling like I was ****d when I was leaving so im good. only problem was truck and car shop stand had a lot of stuff missing and was back at the shop and not there in Pomona. managed to get these things tho that I really really needed like that steering wheel finally
    I have my original 48 cap, this cap will be for sale. and the front motor mounts
    new tail lights
    new turn signal lever
    volt reducers
    new insert for my hood ornament
    and thanks to rich, he gave me a free bracket to see if I can mikey mouse the rear motor mount im missing. if it doesn't work hes got the bracket at home hell sell me so im good. thanks rich (I part out chevys)
    back to work tomorrow, want to get a lot done this week. heres some pictures from Pomona
    best baby carriage I ever seen, was 350 bucks
  4. gallogiro
    gallogiro
  5. gallogiro
    gallogiro
  6. chevy54man
    chevy54man
    from NC
    Great job you're doing on this Chevy and great pics too!
  7. gallogiro
    gallogiro
    Monday, back to work. old dirty transmission
    cleaned up and painted
    ok does this look familiar to any of you guys? its what was busted on my transmission. the lever was broken on this link but what was holding it together and broke was a thin weak piece of metal. is this how it is supposed to be or was this a mikey mouse repair?
    look what I found when I went inside to look for my clutch throwout fork, my missing motor mount =D
    ok finally bell housing swapped, and flywheel and clutch installed
    and transmission bolted in, got my motor mount and mounts, am ready to drop the motor in =D all that's left to do that is do the firewall which im doing tomorrow
    now motor mounts complete
    ill be driving this thin in days. tomorrow back to work
  8. Cool build! Question about the peel n seal: Did you put it on the doors also or just the floor boards?
  9. gallogiro
    gallogiro
    ok so today I got down to working on the motor again. my problem was that the starter that came with my motor was changed to a solenoid start not a pedal start. I didn't want that. but I couldn't use my old starter because when I took it off it dropped and broke an ear. this is what I did
    anatomy of a starter
    ok the problem. old starter, was pedal start but broken ear
    new starter, good ear but solenoid push ****on start not pedal start. don't want that
    pedal start
    push ****on solenoid start
    need to swap out the head, start lever, motor and the bottom the brushes
    these screws come off
    armature comes apart
    levers work off a clutch fork style action
    old motor, no good
    armature still good just clean it up
    this cover comes off
    to show screws to take off bottom brush plate
    same on this one
    lever out, no good its a solenoid arm
    put this one on the good head, pedal action arm
    cleaned up the contact conductors
  10. gallogiro
    gallogiro
    and put back on
    old brushes out, new brushes on
    drill a hole for the spring
    this has to line up so you can screw on the brushes correct
    easiest way to mount the motor on the brushes is like this. you have to pull them apart so the motor drops in and its too hard to do with the cap on on the bottom
    holes on new and old cap didn't line up, this wont work the lever and conductor ****on wont line up
    make a template off the old head with a piece of paper and grease off my finger
    drill the new hole
    and tap it so the bolts thread into it
    put cap back on, run the long bolts back in and screw them in the new tapped holes. then put the screw to connect the brushes to the armature
    disengaged
    engaged (pedal pushed)
    put cover back on
    good to go, pedal start converted and rebuilt
  11. gallogiro
    gallogiro
    thank you =) this is a home build not a shop build so its what anyone can do in theyre back yard
  12. chevy54man
    chevy54man
    from NC
    That is why I am really liking what you're doing! Best to you and yours!
  13. gallogiro
    gallogiro
    thanks =) so far just the floor but I am slapping a layer inside the door after I clean it off and SMALL CUT PIECES on the underside of the roof. small pieces will stick even in the heat, one long piece will be heavy and with the heat will weigh it down and cause it to sag and fall off. you can put long strips, but be sure to get a razor blade and after its put on cut it every 6 inches and itll be just a series of small pieces
  14. gallogiro
    gallogiro
    won this on ebay, anyone have any info on it? thinking it might be too new for my 48, but not white or blue to match my 59. anyone seen this one before? willing to trade for a hull beaconlight (oval) comp*** with bracket or the space egg looking 50s hull comp*** with bracket. pm me if one of you guys have one
    [img width=700 height=525]http://i5.photobucket.com/albums/y161/reyes213/48/2013-06-06132725_zpsbab3829f.jpg[/img]
  15. gallogiro
    gallogiro
    took a look at this before I got going with my night, ok I have 2 intakes and header off 2 different motors. what is it I have to look for when putting one on? is there anything that can make the intake/exhaust manifolds bad? and on both of mine, this doesn't move
    is that supposed to move or stay still? also, I have 2 carburators. whether they are good or need to be rebuilt, which one is better? one is a carter, the YG I think it is. the one on the left and the one on the right is a Rochester. which is better?
  16. gallogiro
    gallogiro
    ok so this is where it all leads too, all caught up to today june 9th 2013 where im at at this point. there is progress every day, so check in every night about 9pm pacific. this car should be painted in a few days, and on the road driving in about 2 weeks
  17. gallogiro
    gallogiro
    thank you. and yea if I can do it anyone can, I have no school or training just me and my socket set, grinder and eastwood spray gun. its just a matter of getting dirty and possible by anyone =)
  18. gallogiro
    gallogiro
    as for the interior, I was taught how to use an industrial sewing machine and bought my own for 400 bucks on craigslist a WALKING FOOT machine. so yea for that youd need a special tool to get the seats done. but the rest of the interior, its just a matter of cutting out old panels and gluing and stapling fabric to it. and the door panels since the threads wont have to hold the pressure of someone sitting like it would the seat, you can use a home sewing machine to make the patterns on the door panel and just staple/glue the fabric to the new cut panel board and install it. I used a singer home sewing machine to make the door panels so you don't need a big expensive machine
  19. gallogiro
    gallogiro
    today I finally got all my motor mounts the front and rear. had the fronts for a while, had to find the rears. truck and car shop didn't have the rears I needed, they had some M shaped ones. I and I didn't have them either and in Pomona I didn't find them. only chevsofthe40s had them. but once I got them, realized I could have used the fronts for the rears, its the front and transmission mount that supports the motor and ******, the side mounts are just supports for vibration. so I could have used the fronts for the rears they are same bolt and line up the same and are thick enough just different shape [​IMG]
  20. gallogiro
    gallogiro
    got to get everything done on the firewall so I can drop the motor in. as it sat this morning
    I had hit it before but like a year ago and it got surface rust on it. looks good but you cant tell in these pics cause I took them when It wasn't as bright and the flash makes it look the same like before. but it looks good, metal is good, ready for primer
    figured im dirty, might as well hit this too. even though you cant see it, going to primer it as well and paint it black. not going to be a show car but a very clean cruiser this car will be rust free and everything redone
    ran out of daylight, will primer it in the morning and will post pictures at night. ok, this is obviously original off the firewall on my 48. im still running the generator so I need this right? but because of the cloth wires im guessing its a 6 volt. how can I tell if it is or not? when I bought it, it was running and driving off a 12 volt battery and had a generator. whats the point of this what if I run it without it?
    also really happy right now, I THOUGHT my rear end was seized, thought I was going to have to take it apart and replace whole rear end, or the gears inside the pumpkin, or the axles, or the driveshaft, something whatever it was that caused the back wheels not to turn. well I had the drivers side up and to take the wheel off and yea it was seized, wasn't turning at all like I thought. but when I put up the p***enger rear, the wheel turned. and when I turned the wheel so did the driveshaft that goes into the transmission so I see its good. but does that sound right? only the p***enger rear wheel turns free along with the driveshaft, but the driver rear doesn't? and Im hoping its seized because of the brakes. but is the driver rear wheel supposed to turn with the p***enger wheel or no? do any of you know or know whats going on?
  21. jcmarz
    jcmarz
    from Chino, Ca
    Nice car. You are doing a great job on it and thanks for posting the photos. I look forward to seeing photos of your car when it's finished.
  22. mcnally351
    mcnally351
    from boston
    Good job keep the pics coming, I like the do***entation
  23. Excellent. Can't wait for your thread on the '59.
  24. gallogiro
    gallogiro
    this was hanging off my old coil, but don't have it on my new one. do I need it?
    and found this lever inside the car, but don't remember where it came off of. look familiar to anyone?
    got to work alittle late, but finished what I wanted to get done today. as it sat this morning when I got up
    grinded, little body work and sanding, now its primered
    now just sand the primer and paint the firewall tomorrow and the motor drops right in. rebuild the carb tomorrow night turning it on for the first time Thursday night, driving it by sunday
  25. [​IMG]
    I think it's called a ballast resistor. It keeps your coil from heating up unless you have a newer ignition set up. The experts will have to chime in.
  26. 54rat210
    54rat210
    I'd like to know more about what looks to be a 65,66 or 67 impala under the cover. I love me some call lowriders!.
  27. 54rat210
    54rat210
    The 59 is sick also!
  28. gallogiro
    gallogiro
    thanks guys, and that car under the cover is my 65 impala
  29. gallogiro
    gallogiro
    and the 59 im going to start a thread on the build even tho im almost done. only posting a few pictures, I want the thread im starting on it to do all the showing
    from this
    to this. so far but not done yet, the thread im making will cover all of this
  30. gallogiro
    gallogiro
    the day I got it. ill start the thread soon
