I'm trying to decide on stock manifolds or a block hugger style header for my 392. The car is a '32 5W and everything on it is from the 60's, so I'd like to use something from that era. I don't think they had the block hugger style back then. I do have a nice set of stock cast iron ones that are center dump. Any suggestions? http://www.jalopyjournal.com/forum/showthread.php?t=399544&highlight=another+5w
I've been wondering about the same thing. I like the looks of the stock center dump cast iron headers better than the block hugger - more nostalgia. But am wondering about the "flow" of the cast iron can be improved by Jet Hot coating.
Headers...or at least 1 7/8" block huggers with at 3" collector. More if the engine is heavily souped. Let her B R E A T H E !!! THose Hemi exh ports flow real well, no use chokin the **** outta them with log manifolds unless you have packaging issues or the mill is relatively mild in mods. Rat
I went with manifolds on my 392 because I didn't like the look of any of the block hugger headers and I wanted the exhaust to stay between the frame rails. Exhibit A
Depends...........if horses.....headers If looks an issue, the frame rails.........manifolds Do it correctly..........make your own...........
Sorry to bring this back .. but thanks guys. I am putting a clone chevy 283 power pack dual quad motor in a 32 ford sedan and have been struggling and struggling with block huggers versus 2-1/2" manifolds. I am going with manifolds !
Someone is repoping the centre dump truck manifolds with the 3" outlet and that's what I would run unless I was to build a set of headers that would work - 34-36" long 1 5/8-1 3/4" primaries (depending on power output) into a 2 1/2 - 3" collector. Shorty headers are terrible for performance in my estimation - super short primaries and very turbulent short collectors - manifolds would be better.
HAMBONE...I think rat gave you the right idea! man let that badboy breath. brother there's nothing wrong with headers on a traditional hotrod. hell man just do whatever your BIG enough too...POP.
