Hot Rod Flatz
Discussion in 'The Hokey Ass Message Board' started by oddcraig, Jun 13, 2013.
  1. oddcraig
    oddcraig
    So I am doing some research before I paint my Buick.
    I really like the look of Hot Rod Flatz but am a bit hesitant about using them as they are Urethane based and I will be doing it at home in my garage which wont have full on ventilation etc.
    Anybody used them before at home? Any Tips/ Tricks or alternatives for the same finish?
  2. cutitup
    cutitup
    ive had flatz on a suburban for five years sits outside everyday its my shop truck bad stuff weve done nine vehicels love it
  3. 1beatnik
    1beatnik
    from indiana
    SHAKE THE CAN if you stir it won't lay right and read the directions
  4. sweeden
    sweeden
    Whats the price on it and is it just a single stage?
  5. slammed
    slammed
  6. sprayed freinds 51 ford truck...easy to use..stir well...make sure you jave enough to do job so it all matches...goes on shiny...gets flat after flashing off...great stuff...email me..can send you pics...
  7. Lots of threads on it. I've used it twice in the last few months. Good stuff.
  8. oddcraig
    oddcraig
    Thanks guys. Yeah I did a search and it came up empty so not sure what went on.
    So it is ok to use in the garage? Obviously I will have a respirator etc just more concerned about ventilation. It is only a single stage
  9. BZNSRAT
    BZNSRAT
    Yes, you will be fine..We didn't have any problems..spraying it in a garage
  10. Ignore any government pamphlets pertaining to it! You'll be fine.
  11. rt338b
    rt338b
    from Illinois
    Shaken not stirred as bond says works the best. But yes spray at home and good respirator are needed
