Is this even worth tryin to fix?
Discussion in 'The Hokey Ass Message Board' started by 55fbomb, Jun 16, 2013.
  1. 55fbomb
    55fbomb
    from PA
    got the carpet and seats ripped out yesterday check out the rust damage. the likelyhood of me finding a decent cab around here is probly not too good, would you guys even try to fix this mess?
  2. HOTRODPRIMER
    HOTRODPRIMER
    A lot worse have been brought back,,it's really not that bad. HRP
  3. MannyK
    MannyK
    from NYC
    Its not too bad...
  4. If you are the type of guy who ****s around a lot or is ****ter brained or never welded before that might take a week to fix.
    Other than that I can't see it taking more than a couple days to have a new floor in painted and ready to go.
  5. upspirate
    upspirate
    Depends on your tools, skill,and knowledge levels, and your determination.
  6. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Man, road salt! I'm more concerned with the inner jamb support, rockers and body mounts being rotted away than the floor.
    What type of truck? If replacement panels are not available, you're in for a lot of work. Doable, but a lot of work to do it right.
  7. bgaro
    bgaro
    this is the northeast, we fix.
  8. It`s easy to get overwhelmed with a repair like this. Take one area at a time. Many worse have been saved.
  9. farmer12
    farmer12
    Not too bad at all. Seen a lot worse being restored.
  10. It can be fixed. If it's something you can find a panel for, go that route. It's MUCH faster than patching, plus your seats will fit with LESS drama.
    I've done a few in patches, but when I did my Firebird, I used panels. Costly, yes. Done in a weekend instead of a week.
  11. Dexter The Dog
    Dexter The Dog
  12. hooliganshotrods
    hooliganshotrods
    It's not to bad, I guess it really depends on your skills with metal and a welder.
  13. oldolds
    oldolds
    You are in PA. That would be advertised as a nearly rust free cab. Floor repairs are easy. You just weld them and you are about done. No hours of finishing work, unless you are doing a top dollar restoration.
  14. 31Dodger
    31Dodger
  15. rixrex
    rixrex
    After looking at that fella go for that Falcon Ranchero "Rust Ranch" it seems like anything can be brought back to life..
  16. GassersGarage
    GassersGarage
    It's not too bad. I once had a transmission tunnel made and welded in. I took it to a welding shop, not car related. I showed the guy what I wanted done. He said no problem. It cost me $300 and he was done in 5 hours. Picked it up the same day. He did a great job but was very apologetic because you could see the welds. I told him, are you kidding? I was impressed.
  17. Rusty O'Toole
    Rusty O'Toole
    No it's not. Shut the garage door and go buy a new Hyundai and be happy. Forget the old **** it's old ****.
    If you don't want to do that, then your cab is very fixable. I live in the northeast and have fixed way worse than that, and less desirable bodies too.
  18. Zeke
    Zeke
    Better than what I started with. Have a go at it. worse you can do is **** it up and have to start over.
  19. I've seen worse still being driven down the road.
  20. hell compared to my stuff that's a rock solid start when you have holes big enough to drop small children through with out them touching the edges then its time to start wonderin if its worth fixing
  21. Carbs & Chrome
    Carbs & Chrome
  22. 49ratfink
    49ratfink
    that is pretty messed up. I don't know where you people are getting that it is not that bad. I would bet that once you cut it up to the point of good metal you will have no floor or underlying supports at all.
    could it be fixed? sure. I could fix that for you, depending on what kind of truck it is you could buy 2 or 3 new cabs in good shape for what it would cost, and I work cheap.
    show a picture of the rest of it
  23. 49styleline
    49styleline
    Not bad at all. go for it.
  24. coralhead
    coralhead
    from S. Indiana
    Here's my before and after.
  25. flathead okie
    flathead okie
    That resembles me. :D:D:confused::eek:
  26. bobj49f2
    bobj49f2
  27. 56don
    56don
    I would weld in some support bracing in there before removing too much rusty metal so the cab doesn't fall down over the frame. But you really should take the cab off and fix it in my opinion.
    Funny how its fixable in the NE but useless junk out West.:)
  28. Lmc has everything & everything is at high prices.
    It's convenient one stop shopping for sure but I only get the stuff that nobody else has.
  29. 55fbomb
    55fbomb
    from PA
    thanks fellas, the rest of the cab is decent, even around the drip rail and windshield but i just am unsure where to draw the line between fixing and replacing. im sure it could be saved but when does it stop being time and cost effective. its gonna take me a while to weld all that in, all i have is a tig welder but it should look good if i pull it off. the rest of the truck, 58 f100 by the way, shoulda mentioned that, is probly all salvageable except the one front fender. the cab mounts and floor supports are long gone in this also, its pretty bad. i had to drill out all the rivets and pull the P.O.s previous repairs which im sure made this worse. at least its gutted out a bit to dry now. the old y block started right up though, and its been sitting a while. thanks for the links to repair panels and the words of encouragement.
  30. bobj49f2
    bobj49f2
    Dennis Carpenter has some of the parts, I couldn't find a floor, but they had the step and step well.
    With as many parts needed to repair that cab it might be cheaper to buy from one place to save on shipping costs.
    I have friends in other parts of the country that laugh at the stuff we repair up here. Sure, a nice solid cab is the way to go but finding a decent one up here is getting next to impossible. When you do find one it's usually crazy price. Some of us have more time than money. I know that's usually my case.
