1954 Lincoln front clip
Discussion in 'The Hokey Ass Message Board' started by pistolitas, Jun 17, 2013.
  1. pistolitas
    pistolitas
    from orange ca
    Does any body know what kind of front clip to use on a 1954 Lincoln other then a camero clip I no s10 is to Narrow trying to keep it ford
  2. leadsled
    leadsled
    Why are you wanting to change. these front ends ride good.
  3. blicket007
    blicket007
    from Maryland
  4. S_Mazza
    S_Mazza
    Your car didn't come with one?
  5. pistolitas
    pistolitas
    from orange ca
    Who ever had it before put one in but put it alittle for ward and the tires hit the fenders when I turn it
  6. Rusty O'Toole
    Rusty O'Toole
    54 Lincolns have a unique ball joint that is no longer made. That may be why the PO changed it.
    I would be looking at the late model Crown Victoria front end. It is a good front end for your car if it is not too wide. Or you could try to find a 97 or older Windstar van front end, also very good but a little more work to install.
    Older Jaguars also have a good front end that is not hard to install.
