Any Pontiac guys? Thinking Pontiac 428 in Model A
Discussion in 'The Hokey Ass Message Board' started by GetSome, Jun 17, 2013.
  1. GetSome
    GetSome
    Building a Model A Modified Roadster, set it up for a SBC but I'm thinking of throwing in my Pontiac 428. Only problem is, I haven't built the engine yet and before I throw my money into it......I have about 32 inches of clearance from my firewall to the radiator. Anyone know if thats enough clearance for it to fit?
    I don't know how they compare in size to a SBC. Also wondering if theres any other issues with running a Pontiac compared to SBC as far as clearing steering, the frame rails etc.....so anyone who's thrown in a Poncho in their Rod, please let me know any problems or headaches you've encountered. I just don't like the idea of being another guy with a SBC in a Model A haha, thanks in advance!!!!
    32Stoker likes this.
  2. The same F-bodys that came with a Chevy 350 came with a Pontiac 350, there's not that much difference in size.
  3. treb11
    treb11
    Pontiac starte ris on the Left, so steering can be tight. comparable in length to a SBC
  4. rustisgold
    rustisgold
    Got a 455 in my 35 pickup, built the truck around it, my only complaint is its hard on tires........can't beet a Pontiac in my book!
  5. JYPSEA
    JYPSEA
    from Florida
    Got a 455 in my '35 Chevy pick up. Best engine ever. Kicks *** and takes names.
  6. Deuces
    Deuces
    A 428 with all the SD goodies... That be sweeeet!.:)
  7. Whoa where'd the intro police go ?
    You'll love that 428 in the coupe!!
    It will probably take something beyond 1800 hot rods but it will be just fine.
    kidcampbell71 likes this.
  8. flamedabone
    flamedabone
    Every car I build has Pontiac power.
    '34.
  9. flamedabone
    flamedabone
    Here is the Model A.
    Be mindfull of your starter to to steering box clearance, other than that, it will fall right in there.
    Good luck, -Abone.
    Jet96, kidcampbell71 and brut4s like this.
  10. GetSome
    GetSome
    Thanks so much for the responses and its awesome to see your cars with Poncho power! Guess I better get to building :D
  11. Fresh 406, 2x4's, for my '47 Ford p/u
  12. I think some SERIOUS frame reinforcing is in order
  13. swe64
    swe64
    hello mesured my 1962 389 and space is on car 34inch between firewall to radiator and there is 1inch space at eachside engine is about 32inch from destributer to fan.
    as mentined before leftside is problem a ministarter and factory headers worked for me.
  14. GassersGarage
    GassersGarage
    Groucho ran a 389 in his channeled '32.
  15. JYPSEA
    JYPSEA
    from Florida
    Here's a pic it fits nice in original engine compartment with electric fans in front of the radiator.
      514.5 KB
  16. 30panel
    30panel
  17. Pontiac Slim
    Pontiac Slim
    yet another..
  18. GetSome
    GetSome
    You guys are awesome! Thanks so much, so nice to see some Pontiacs bein run!!! JYPSEA even has some Lake headers, looks killer!!!
  19. Hell, the ****ram 1/8th scale Big Deuce kit comes with a Pontiac engine.
  20. best2923
    best2923
    from north Id
    pontiac's run if you build them right the old man ran a 350 in his 66 lemans dirt stock car.
  21. Vintage Vandal
    Vintage Vandal
    I would just keep the 350 in it. Ya know, something different.
  22. pontman
    pontman
    Use this one as an example!
  23. It would definatley be different and cool..evreyone has a small block...good luck with the build!
  24. jimmy1931
    jimmy1931
    Here is my '31 Chev with a 389. Custom headers & frame notched for steering box, along with custom fabbed blower drive, but everything fits old school. Flamedabone has the most *****in & fastest traditional street rods powered by Pontiac in the whole world. HE IS THE REAL DEAL! Come check him out at HAMB Drags.
  25. handmedown40limited
    handmedown40limited
    from tracy ca
    my 455 in an OT 68 gto had 6x-8 heads(smogger 400 heads) xe274 cam by comp. Peroformer rpm intake edelbrock 800. Stock rods with arps. Forged pistons. All casting flash was cleaned up inside the motor for oil flow back.a good balance job and a tuned hei 32*by 2200 with 12 initial.
    with a th400 2400 stall 3.42 12bolt would run consistant 13.2 anyday everyday. I believe it weighed in at 3900lbs. When I pulled the motor out to swap in a 350 Pontiac to sell it I found a kink in my fuel line. Should have been a easy 12 second car.
    built it when I was 17. Got in lots of trouble with it. I would build the exact motor in a heart beat.
    with your 428 I would duplicate it but 6x-4 heads with a clean up. Good vacuum great sounding idle. More torque then u will ever need. I delievered pizzas in that car and put 60k plus in 2 years. I miss it.
    ken
  26. GetSome
    GetSome
    It's killer to see all the cars and fellow Poncho lovers! Thanks for all the input and comments, you guys are motivating me haha!
    I think you guys will probably slap me for even thinking of the way I want to build this Rod though.....probably shouldn't even mention it lol
    As far as the engine specs, I don't quite know them yet. My brother was actually going to build it with me just before he p***ed away....so it's all cleaned up and waiting for me to build it at his old shop. I'll keep you guys posted!
  27. GetSome
    GetSome
    Yea, about as uncommon as Crossfit & tattoos
  28. sko_ford
    sko_ford
    I have a 400 in my mod but I have enough room to run a 6
    Stock except the p4b\650 carb & lakes headers
    brut4s likes this.
  29. GetSome
    GetSome
    That is awesome! What are the chances, another Mod out there with a Poncho! That's quite the steering arm!
