Projects Recreating the jesse lopez coupe
Discussion in 'Traditional Customs' started by jivin jer, Aug 18, 2012.
  1. PeteFromTexas
    PeteFromTexas
    Looking good Jer.
  2. MannyK
    MannyK
    from NYC
  3. jivin jer
    jivin jer
    Here we are checking the profile to see what it looks like. I did have a template shot in the shop that I accidently deleted. I have one for later outside. Making sure (once again) that everything is even side to side.
    If I remember correctly the original feature on Duane Stecks driveway build (Moonglow) showed that the top was cut only at the front and rear pillars. There weren't any bizarre trips out into the sheetmetal part of the top.
    It's the same thing here. No cutting the top in 1/2"s or 1/4"s. None of that stuff. We'll leave that to superman.
  4. koolkemp
    koolkemp
    The 4 door roof? I used a chunk of it for my chop, the rest is gonna fill the roof hole on my someday 36 project...always recycle lol!
  5. Torchie
    Torchie
    Great philosophy Jer. It is exactly the way I approach the custom that I am building.
    It ain't rocket science so don't over think it.
    Keep up the great work as I and many will be using this a primer for chopping the 41-48 Fords.
    Torchie
  6. greybeard360
    greybeard360
    Seeing the wrap on the rear springs reminds me of the 40 Chevy I did for a customer. The rear springs were wrapped in tin. We removed the tin to find one of the main leaves was broken. I took them to Ft Worth Champion spring and they made a new leaf and rebushed them... looked like new then !
    I am anxious to see this one when done... glad you are in the neighborhood !!!
  7. jivin jer
    jivin jer
    Well, I was here before you, via email. Jesse has said that the cuts didn't go above the b/gl*** opening. Here we are very carefully trying to see how this will work. It won't work. There's too much resistance against this "slice" too let it conform to where we need it to go.
    We also see the hole that Jesse tried to bridge with the chicken wire.
  8. jivin jer
    jivin jer
    Here's a better look at the top in the correct position. The rear corners are tacked so they don't move. Another look at that space that Jesse was trying to bridge with chicken wire.
    This is probably close to the "sonofa*****" place he was at. Not quite to the "it will tell you what it wants" place.
    We are trying to get there. We know what we can't do with Jesse's info (about the slice's) at this place and time.
      211.6 KB
  9. finkd
    finkd
    this is one of the hardest chops I have ever done,( 19) at this point what I see is cut it above the drip rail and take the corner out, leave the back window opening intact, and let it hinge, get the backgl*** where you want it and then go back to the corners after you get one thing where you want it. you might have to cut the roof and add a piece all the way across above backgl*** to make roof longer. and then you can cut up the corners and add filler metal on side between driprail and quarter gl***. and I'm sure you know, but the backgl*** is double curved and tempered so you cant cut it. you will be doing a plexigl*** or have timo build you one which runs about 10 grand for a windshield. no sure on back gl***.. I have really enjoyed your build, can't wait to see it done.
  10. jivin jer
    jivin jer
    Remember, this is 1948-9, not 2013.
  11. mikes51
    mikes51
    30 years ago I could have bought a running 50 merc for 3K and it even came with an extra roof! I goofed and didn't buy it. But what it reminds me of is in the old days, extra roofs were plentiful and they must have used them often to eliminate that bump in the back.
  12. jivin jer
    jivin jer
    I sent this to Jesse so that he could see what was going on.
  13. Karl stark
    Karl stark
    What was his response?
  14. jivin jer
    jivin jer
    Jesse is a low tech guy. No cell or email.
  15. BrerHair
    BrerHair
    Haha! Love it. Gonna take a boatload of chicken wire!
  16. jivin jer
    jivin jer
    Snail mail is Very frustrating at times like this. I think I'm at the place where this top IS telling me what it wants. I'm tempted to go ahead and do the obvious while I'm waiting for Jesse.
  17. rob-redm
    rob-redm
    My parents are the same way, well almost. Have a cell for emergency
    only. They won't use it. Lap top PC, but not used except for solitaire at
    times. Just needs to grin and bear it. Keep the updates coming
    Jer!
  18. OLLIN
    OLLIN
    Do you mean cut the rear window out, and the sides and then make sail panels? kind of like like how finkd did it?
  19. jivin jer
    jivin jer
    That's definitely NOT the vibes I'm pickin' up.
  20. Cla99ude
    Cla99ude
    from usa
    It will be (like Junior’s) a fun ride for everyone as well as a tribute to Jesse’s early years and those around him and that era.[​IMG]
  21. jivin jer
    jivin jer
    I couldn't wait for Jesse to get what I had sent him so I could talk to him about it. I realized that I've already talked this thing to death. So I went ahead and slowly crept my way upward with that slice at the b/gl*** opening until I found the sweet spot. When I did, all of a sudden, everything made sense.
    Sooooooo, here we are at that sweet spot where the top says that's it, that's what I want. It's just above the resistance line and, below the crown of the top. When you find that spot everything starts to work.
    Here's Jesse's slices and what Gene Winfield calls **** Deans ribbons (see post #686). I don't know if Sam Barris had a name for it.
      220.2 KB
  22. BrerHair
    BrerHair
  23. eric54chevy
    eric54chevy
    from TEXAS!
    Anxiously waiting, looking great
  24. Tnomoldw
    Tnomoldw
    :)That's the thing we been looking for. Very cool ...:cool::D
  25. jivin jer
    jivin jer
    The angelic chorus has completed its program and, it was very impressive.
    Now that all the racket has stopped I can get going on the rest of this top. I've made a tool to help with any contour issues I might have.
  26. jivin jer
    jivin jer
    We have started the fab work.
      226 KB
  27. BLUDICE
    BLUDICE
    I don't see any chicken wire?
  28. rob-redm
    rob-redm
    No chickens on this build for sure.
  29. Looking great Jer as I knew it would! Do you suppose Jesse meant not above the "rear" window (as in 1/4)? Just sayin' that would fit with what you've done..
    -Dave
  30. jivin jer
    jivin jer
    Well, the actual "hands on" effort is showing that he could have meant that, for sure.
