Hot Rods Upholstery backing board.
Discussion in 'The Hokey Ass Message Board' started by 34Larry, Jun 20, 2013.
  1. 34Larry
    34Larry
    What is used as upholstery backboard these days? :confused:
  2. pitman
    pitman
    Reasonable, were the Model A Lebaron Bonney panels. I used to cut up micro-bus flat panels, and bond the upholstery to patterns cut from them.
  3. Da' Bomb
    Da' Bomb
    I see guys use chip board (upholstery cardboard)
  4. madmak95
    madmak95
    The plastic cardboard like they make signs on the side of the road with. After and election u can find them everywhere.
  5. 35WINDOW
    35WINDOW
  6. flathead A
    flathead A
    from michigan
    I'm with 35window,I've seen guys use 1/8 pvc,works well and you can bend it with a little heat,I'm working n my interior now and plan on using pvc.
  7. 51woodie
    51woodie
    Expanded PVC gets my vote too. If you have a high end lumber yard around they might have it and it's lots cheaper. I think I was paying $80 for 3/4" 4x8 sheets.
  8. Dreddybear
    Dreddybear
    PVC, luan board, Chipboard. For tiny things sometimes aluminum sheet.
  9. 34Larry
    34Larry
    Thanks to all who responded.
    The_CarMan likes this.
  10. OLDSMAN
    OLDSMAN
    I used pcv in my convertible, It worked out great
  11. Atwater Mike
    Atwater Mike
    PVC. I get 'em mixed up too. 'smog in m' noggin'
  12. ibflyin
    ibflyin
    from Tulsa, OK
    Your local upholstery supply house will have waterproof (actually water resistant) panel board in a couple of different sizes. It's reasonable priced and easy to work with. You can cut it with a razor blade and it will hold a staple(s) for attaching your material. PVC might start showing some waves after being exposed to hot and cold, especially the larger panels. Another option is fiberboard, like you get at Lowes/Home Depot, but it's not as resistant to moisture.
    Just my $.02...
    Devin1950 likes this.
  13. 40StudeDude
    40StudeDude
    PVC will actually "melt" and bend with enuff heat in the interior...or as a package tray.
    There is no such thing as "waterproof" cardboard...'water resistant' yes, but eventually it will warp if it ****s up too much water (rainwater or washing your car).
    Luan wood is the same as cardboard...it too, will **** up water and warp.
    Black 1/8" thick upholstery plastic is available from most upholstery supply houses in 4' x 8' sheets ...it won't warp from heat and will not **** up water but it is not cheap...of course, IF you want to re-do your door panels every couple of years cuz they've warped, use something cheap...
    R-
  14. 29moonshine
    29moonshine
    i use 1/8" white tile board you buy at lowes [it is used to go around a tub or shower] comes in 4x8 sheets
  15. bobj49f2
    bobj49f2
    A friend of mine used bathroom paneling he bought on close out at a local big box home improvement store. It had chips and cracks but it was cheap.
