I need some Ford 300 help... PLEASE!!!!
Discussion in 'The Hokey Ass Message Board' started by HeX, Oct 9, 2005.
  1. HeX
    HeX
    I know it may be a little ot but, bear with me.......
    I have a '65 econoline pick-up........It has a 1979 Ford 300 in it........the valves need adjusting....
    Does anyone have the valve-lash specs for a '79 ford 300? Anyone happen to have a manual covering valve lash etc...?
    Thanks in advance for the help.
    Tim
  2. FiddyFour
    FiddyFour
    Hex...
    i looked around on the net, couldnt find **** so i posted the question on the fordsix 300 forum,,, i'll letcha know what i find meng:cool: i do have a chiltons manual for late 80's early 90's ford trucks, i'll look in there to see what the specs are, but i donno if the lash settings are gonna be the same
  3. HeX
    HeX
    Fiddy -- Man I appreciate it!
    Let me know if you hear anything.............
    Thanks again.
    Tim
  4. Knicky
    Knicky
    look up Ford Truck Enthusiasts. com those guys know about that motor pretty good and have helped me out a lot.
  5. jalopy43
    jalopy43
    I saw no specs listed for the 300. Arn't the lifters hydraulic? Sorry I am of no help. BTTT:Dsparko
  6. krooser
    krooser
    hydraulic....non-adjustable
  7. Croaker
    Croaker
    from Kansas Ks
    hydraulic lifters , no adjustment if you hear clacking could be colapsed lifter or bad lobe ,s on cam
  8. FiddyFour
    FiddyFour
    yup... hydro=no lash...:rolleyes:
    this is what i got from the guys over at fordsix
    hope that helps:cool:
  9. HeX
    HeX
    Thanks everyone.....I guess................
    The good news is the HAMB came through again..........The bad is that it sounds like my problem just got a little bigger...........Oh well, could be worse, I guess..............
    Thanks again.
    Tim
  10. willowbilly3
    willowbilly3
    from Sturgis
    It depends on the year, but some are adjustable and some aren't. If you have the non tapered studs you can adjust them just like a chevy. My 72 has the adjustable style and I do remember there were 4 different variations on the rocker arm/studs, but that was a couple decades ago when I was head hunting for the old girl. If you have the tapered studs they will be non adjustable, just tighten til they bottom out. No reason you couldn't throw a washer under a good lock nut and adjust any of them if you need to. It is not uncommon to have a noisy lifter. My original engine had an intermittant noisy one for years before I rebuilt it. And FWIW, you would be amazed how much you can wake up a 300 with a little headwork and a Comp 260 cam.
