Build up on my '54 4dr chevy belair!!! Got it home and was checking out and rea
Discussion in 'The Hokey Ass Message Board' started by Jbuhl1954, Jun 10, 2013.
  1. Jbuhl1954
    Jbuhl1954
    ImageUploadedByH.A.M.B.1370872956.034084.jpg ImageUploadedByH.A.M.B.1370872978.192177.jpg ImageUploadedByH.A.M.B.1370873014.239519.jpg ImageUploadedByH.A.M.B.1370873058.168795.jpg ImageUploadedByH.A.M.B.1370873085.179414.jpg ImageUploadedByH.A.M.B.1370873120.315379.jpg ImageUploadedByH.A.M.B.1370873140.631144.jpg
  2. Jbuhl1954
    Jbuhl1954
    Sorry wrote the **** in subject box!!! Lol!!! So just cutting some floor out and replacing!! Ill have more photos as I go along!!!!!
  3. arkiehotrods
    arkiehotrods
    New floor plans are a beautiful thing! Glad you're doing what needs to be done to get your car on the road!
  4. Jbuhl1954
    Jbuhl1954
    Thank arkiehotrods!!! Ya ready to get on road!!! Also going to do a power brake conversion so it is safer!!! (Per the wife) lol!!!
  5. jfreakofkorn
    jfreakofkorn
    good looking car and getting new floors ... nice ....
  6. chevy54man
    chevy54man
    from NC
    Best to you on your '54, love that car!
  7. Jbuhl1954
    Jbuhl1954
    Thanks man!! Gotta get it solid and ready for the road!!!
  8. Jbuhl1954
    Jbuhl1954
    Thanks chevy54man!!! I see you had one previously!!! Great cars to fix up!!!
  9. Jbuhl1954
    Jbuhl1954
    Got the driver front and rear pans ready to go... Just gotta finish out rocker panel first and bam it's on!!! ImageUploadedByH.A.M.B.1371256357.218880.jpg ImageUploadedByH.A.M.B.1371256391.487657.jpg
  10. Jbuhl1954
    Jbuhl1954
    Got the rear driver pan fitted and welded in!!! Front pan tomorrow!!! ImageUploadedByH.A.M.B.1372037918.541467.jpg ImageUploadedByH.A.M.B.1372037974.931600.jpg
  11. 49ratfink
    49ratfink
    so nice to see someone is making a proper pan for these cars. they also make the piece in the middle where you didn't get one. I have one for a 49-52 I may be putting in.
  12. 54rat210
    54rat210
    I'm replacing my rockers. Dunno what they looked like pre rot. The were full of Lots of rot. Can you take a couple pics of rockers for me jbuh?? I don't have anything to go off of. I would really appreciate it fellow owner of a 54. :D;)
  13. Jbuhl1954
    Jbuhl1954
    I am only having to redo my driver front rocker.. The rest look pretty decent just patch work on them... ImageUploadedByH.A.M.B.1372113283.310851.jpg cut away unusable metal and cleaned up...
    ImageUploadedByH.A.M.B.1372113370.095556.jpg took a one by one square tubing and went from kick panel to B pillar and welded in on front side of rocker.. ImageUploadedByH.A.M.B.1372113501.800553.jpg did this to make a little stronger and make base for panel on top... ImageUploadedByH.A.M.B.1372113689.901631.jpg cut out a panel to fit across!! The rocker was decent to start just about a 7" piece on inside was real bad... Cleaned all unusable metal out.. Weld panel on top and then patched the inside rocker to the top... Got a little bit of patching in the kick panel but all and all not to bad!!!. ImageUploadedByH.A.M.B.1372113951.003762.jpg I hope it helps!! I don't have a lot of fancy tools and such I just get in the garage and try to get it done!!!
  14. 54rat210
    54rat210
    Thanks for the photos. Much appreciated.
  15. Jbuhl1954
    Jbuhl1954
    No problem 54rat210!! I post more when I am able to get back out at it!!!
  16. Jbuhl1954
    Jbuhl1954
    Got my front pan done!! Got a little patch work to fill it all in but damn I like these pans!!!! ImageUploadedByH.A.M.B.1372955979.813197.jpg ImageUploadedByH.A.M.B.1372955998.578888.jpg
  17. Jbuhl1954
    Jbuhl1954
    Been a little bit since last post!! Got driver side pans done..
    Now onto p***enger side rear pan..
    ImageUploadedByH.A.M.B.1378704830.221363.jpg ImageUploadedByH.A.M.B.1378705979.601163.jpg ImageUploadedByH.A.M.B.1378706016.631625.jpg ImageUploadedByH.A.M.B.1378706047.865282.jpg ImageUploadedByH.A.M.B.1378706086.669907.jpg
    Fixed up the front rocker..
    ImageUploadedByH.A.M.B.1378707200.047379.jpg ImageUploadedByH.A.M.B.1378707221.609722.jpg ImageUploadedByH.A.M.B.1378707241.397250.jpg
    Check fitment of front pan almost done...
    ImageUploadedByH.A.M.B.1378707394.800711.jpg ImageUploadedByH.A.M.B.1378707416.038760.jpg
  18. Jbuhl1954
    Jbuhl1954
    Got the pans done so onto the trunk!!! Then I decided since new trunk I might as well get on with bagging my sweet girl!!! ImageUploadedByH.A.M.B.1379736748.465452.jpg ImageUploadedByH.A.M.B.1379736866.060028.jpg ImageUploadedByH.A.M.B.1379736895.094230.jpg
    First beads I have laid in about 5 years!! Ill take it!!
    ImageUploadedByH.A.M.B.1379737181.437665.jpg ImageUploadedByH.A.M.B.1379737227.975238.jpg ImageUploadedByH.A.M.B.1379737249.447556.jpg
    One notch done now on to driver side!!! #garagebuilt
  19. Jbuhl1954
    Jbuhl1954
  20. Jbuhl1954
    Jbuhl1954
    5559
    from tn
    looks like its coming along good
  22. Jbuhl1954
    Jbuhl1954
    Got the driver side notch done tonight!!!
    ImageUploadedByH.A.M.B.1379809252.832235.jpg ImageUploadedByH.A.M.B.1379809262.165171.jpg ImageUploadedByH.A.M.B.1379809277.332312.jpg
    Bang!!!
