I can't seem to find it with a search. I know someone has to know what part number to order from the local parts store that will fit my 49 chevy pickup. They measure 9 inches and have I hook to hold em on. I bought these in about 01 and it wasn't hard to get. Seems to be now though. Thanks
Try these guys, maybe you can use an inch longer or shorter either way ? https://www.newportwipers.com/optacc.php Or : http://www.nationalchevy***oc.com/wiper_blades_arms
I went to O'Reilly and they hooked me up on my '54 Chevy 210. Exact same that came off. Back was even metal.
Napa shows this one http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=ACO600116_0344466891 Chevs of the 40's shows these https://www.chevsofthe40s.com/detail/18629/Wiper_Blade_Stainless_Middle_Insert_Type_10_Use.html I used MG blades on my 48 and modified a set of arms for a later Chevy but will most likely go back to chrome arms when it goes back together.
Thanks guys. I found some on eBay. Not exactly like the old ones but will work to p*** safety inspection.
****, I just bought wipers for our model A (Newport Wiper system, but cl***ic bayonet attachment). The wipers I got were 10", from Oreiley's, they were Trico Cl***ics I believe, and had the attach for both bayonet style, and the hook like our GMC takes.
I bought the shortest blade I could and then took my 57 blades apart and cut the longer rubber down to the correct length.
