ROSS Steering box
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 27, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    Got a ROSS Steering box for free.
    Marked:
    Cover = ROSS T225998
    Housing = ROSS TA 142985
    It looks like it was never machined...There's No mounting holes.
    It's really tight!
    Question:
    1. What's it from and is it any good?
    2. If worth it I Have to find a Pitman Arm and steering wheel hub...What fits? Any Sources?
  2. fenderless
    fenderless
    from Norway
    Maybe from a forklift or tractor?
    Can be used on a Dragster or Altered:D!
    Taildragger&fenderless
  3. Kerry
    Kerry
    Nice score!
  4. Marty Strode
    Marty Strode
    It is out of a 67 and older VW Bus, they used one built by ZF along with Ross. To use it drag link fashion the pitmon arm will have to stick up. You will need a clamp mount like the one shown, it is a great steering gear.
    ottoman likes this.
  5. dwrfab
    dwrfab
    from Dallas TX.
    That box is also out of old Crossly,s Around 1948 or so. In a dragster the box is mounted with a plate on the right side. And the shaft is extended to around 12.5" from center of pittman arm to center of box. A Corvair Pittman arm will fit but may be too long for some installations. Not sure about the steering wheel end.
    dwrfab Don Ross
    www.donrossfab.com
  6. Marty Strode
    Marty Strode
    Don,These Ross boxes are out of Crosleys, I think from 49 and later, notice the mounting ? Did the earlier ones have a clamp style mount? Until the OP checks the rotation it will be hard to know the real application.
  7. Marty Strode
    Marty Strode
    Here are the pics.
  8. Normbc9
    Normbc9
    This Sterling from 1949 had a Ross "Cam and Lever" steering box and it is still doing its job for the past six decades. Parts are available from the Sacramento Truck Center in West Sacramento, CA. Some are "Pre-paid; Special Order."
    Normbc9
  9. dragsled
    dragsled
    from Panama IA
    Good Score , that's what I'm useing in my dragster,,,, Tim Jones
  10. rd martin
    rd martin
    from indiana
    they used the ross boxes in alot of things, also used in powerking lawn tractors in the 60s early 70s. there is a guy in 12 mile indiana called service crosley. he has a crosley parts business, he has a load of boxes. i got mine there for my f.e.d.
  11. 61cad
    61cad
    Got one in my dragster.... Right hand steering
  12. silversink
    silversink
    they were used in a lot of vehicles. The ones I have come from International pickups 1941- 48
    Speed Gems likes this.
  13. 1933t
    1933t
    from Buffalo NY
    Bingo Marty I have one in my car same one it worked for almost 50 years here I Like them
  14. 340HilbornDuster
    340HilbornDuster
    Any ideas where can I find a pitman arm for it?
    Mahalo
    T
  15. if I'm not mistaken they also used ross in some early jeeps like cj2a
  16. cruzincougar
    cruzincougar
    I picked up a Ross box at LA Roadsters swap meet last weekend. The guy had 3 10 gallon drums of them. He told me they came of of 3 wheeled mail delivery vehicles. He didn't have any pitman arms for them and didn't know what would fit. I figured for $30 it was worth a try. Came home and took the arm off the original '31 Chevy box from my roadster and it dropped on like it was made for it.
  17. 340HilbornDuster
    340HilbornDuster
    Awesome, thanks for the TIP Man!!!
    T
  18. steel rebel
    steel rebel
    Pulled a reverse Corvair box out of my roadster and installed an old chrome Ross given to me by a friend. Hoping it would work as good as the Corvair. It is at least as good. But maybe it is all in my head but works good. Corvair arm fit right on it. Splines are pretty much standard so probably a lot will fit.
  19. cruzincougar
    cruzincougar
    I'll be danged, I put the old Chevy arm on a Corvair box. It fit! Maybe if I could have found the 'vair arm, I would have tried it first. I've been trying for a while to find a box that will work on my roadster. Tried Vega, car's too low, 'vair, arm goes the wrong way even though reversed, 'stang, same thing even reversed, and I gave up on the 31 box even after finding new bearings, isn't the internet wonderful. Hoping the Ross is the answer.
  20. Ross built a lot of different steering gears. Both my Flxible Clipper and my Autocar came with Ross steering. I wasn't aware of the lighter units.
  21. NORSON
    NORSON
    Picked up this aluminum Ross box at the Monroe swap meet. I liked the idea that it was aluminum and thought it might be an Anglia. The ford logo on the arm would seem to confirm it. It's a cross steer unit so steers backwards.
    Norm
  22. cruzincougar
    cruzincougar
    needed a universal for it, tried the one for a Vega box, bingo!
  23. Boss Hydro
    Boss Hydro
    from Phila
    Looking for a good Ross Steering box like this one. This one has a bad worm gear, so one for parts only would work too... Thanks in advance..
    Rocky,
    jptrans@prodigy.net
    215-292-5512
  24. dreracecar
    dreracecar
    from so-cal
    Is it any worse than this one???
  25. Boss Hydro
    Boss Hydro
    from Phila
    I'd like to thank everyone for their help! Thank you Jon Fritch for
    coming up with just what I needed!
  26. Jeep67
    Jeep67
    I have the same box in a 1942 Toro tractor I am restoring. 340HilbornDuster, would you be willing to sale me your box?
  27. krylon32
    krylon32
    from Nebraska
    Check the pitman arm on a Gleaner Baldwin Model A combine. I've taken several Ross gears off them.
  28. Damn it Marty I was just going to tell him some BS and talk him out of the box. Then you come along and tell him how good it is. I thought we were friends. :rolleyes: :D :D
    @340HilbornDuster sometimes manufacturers shipped parts without the final machining because that would work for multiple applications. Looks like what you got is an NOS Ross Box and you can make it fit whatever your application may be. it would be sweet not only in a dragster but also in a Model A or a T. it is compact and wants to go in a light car that goes really fast.
  29. 30 Koop
    30 Koop
    from Colorado
    Does anybody know where I can get a steering wheel hub for a ross box? It is a tapered 1 in. shaft with a keyway. Thanks
  30. 1934coupe
    1934coupe
    Koop I have one I think it measures 15/16" you can have it. Send me your address and I'll ship it out.
    Pat
