flat white on the cheap?
Discussion in 'The Hokey Ass Message Board' started by Post Apocalyptic Kustoms, Jun 28, 2013.
  1. Post Apocalyptic Kustoms
    from Outside
    I'm trying to achieve a flat white paint on the cheap that will weather well and not stain bad. Wondering what you guys have used if you've done it?
  2. Matt Kvamme
    Matt Kvamme
    I once used flat white Rustoleum reduced with acetone and sprayed it with my spray gun. Honestly turned out pretty good and lasted a few years. Sorry for the ****py pic, its the only one I could find.
  3. K13
    K13
    I would just get a single stage white in a less expensive line of paint and have the paint store put a flattening agent in it.
  4. chop32
    chop32
    My painter buddy shot the white on my '49 Ford in flat white Rustoleum, also thinned with acetone, but it went on a little thin and didn't have any POP to it...I re-shot it after he left with straight out of the can rustoleum and it came out great.
    When I re-did the tail lites, I just sprayed it with rattle can rustoleum and it blended nicely.
    Id recommend a good sealer coat prior to the white, as everything tries to bleed through.
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
    What he said....probably can buy a gallon for a little over a 100 bucks
