Projects My AV8 flathead build.. blown...
Discussion in 'Traditional Hot Rods' started by hotrodderhaag, Jan 28, 2013.
  1. Hotrodmyk
    Hotrodmyk
    Nice work, what a great build!
  2. klawockvet
    klawockvet
    I have a similar column drop. I built a gauge mount that follows the contour of the tank out of sheet aluminum, polished it and put a 4k tach on the left and a water pressure on the right. The light switch is to the left of the column and an identical wiper switch to the right. I will put an oil pressure in the left and move the tach to a Sun bucket when I find one with a low rpm tach. BTW, The hole in the middle of the F1 steering is the same and I think you could adapt a switch down there, but I could never find the parts cheap enough so I went this way.
  3. hotrodderhaag
    hotrodderhaag
    Very nice! Well done . That's a great idea. Ill keep it in mind
  4. hotrodderhaag, I've enjoyed following along with your build. I love the car and how you've put it together. Also, wanted to mention the newest edition of Street Rodder magazine has an article on a similar supercharger to yours. I haven't read the whole thing but thought you might find it interesting.
  5. hotrodderhaag
    hotrodderhaag
    Hivolt,
    Thank you! The car came together well. There are always alot better car builders out there, but I'm happy with mine. I have till the day I die to improve it. I bought the magazine last week .. Good article.waiting on part two.
  6. hotrodderhaag
    hotrodderhaag
    Well it's alive! Runs very poor under a load due to no vacuum brake for the dist. It's not as critical on a new crab style. But very much on the helmet style . Once the adapter comes it will run perfect. But it stops great and needs a slight alignment. But I finally drove it!!
  7. hotrodderhaag
    hotrodderhaag
    And here is my non traditional throttle linkage. I did what I had to do. Maybe eventually ill find a 32' pedal and do it correctly.
  8. greaser
    greaser
    That was fun....thanks for the ride!
  9. Rust n' Chrome 99
    Rust n' Chrome 99
    awesome, who is the fat *****, didn't catch her!!
  10. hotrodderhaag
    hotrodderhaag
    Ha whoops , every time I video something , my mouth gets herd. Some lady that was tailgating .
  11. Rust n' Chrome 99
    Rust n' Chrome 99
    LOL, funny. I hate *** riders, I usually slow down if they want to be up on me like that. Can't wait to see this in person, the Erie cruise ins started. Erie, PA - Friday - Cruise-Town Downtown Erie between 4th and 12th Streets, 6:00 pm – 10:00 pm.
    June 8, 2012
    July 27, 2012
    September 7, 2012
  12. hotrodderhaag
    hotrodderhaag
    Installed carb adapter for vacuum. Worked good, spun the tires leaving the driveway, ran right up to 65 all the way into town. Headed home and engine was at full temp, started running bad. Still trying to figure that one out
  13. hotrodderhaag
    hotrodderhaag
  14. Carter
    Carter
    If it's running bad when hot, good once cooled off, I would suspect coil.
  15. hotrodderhaag
    hotrodderhaag
    I bought that coil adapter , I got a good deal on it. But I'm gonna try swapping out the factory coil for a good spare I have . See what happens. Condenser is next
  16. hotrodderhaag
    hotrodderhaag
    Found the issue , leaking condenser and also a bad advance brake spring. Some one cut it down. Car runs excellent. Test drive tomorrow will really show the results , but so far so good ImageUploadedByH.A.M.B.1371094637.551979.jpg
  17. hotrodderhaag
    hotrodderhaag
    I'm sure my neighbors love me. A few hole shots in the driveway last night really showed me the car seems to run great. If its not pouring down rain ill have a good test run video.
  18. roseville carl
    roseville carl
    Sounds like you're having fun now!!!!..................
    Nothin like a blown flattie to put a smile on your face!!!
  19. travj31
    travj31
    from Western PA
    Its been 4 hours since you posted this... no rain here south of Pittsburgh, anxiously awaiting videos!!!!
  20. hotrodderhaag
    hotrodderhaag
    No video cause it still runs like ****
  21. hotrodderhaag
    hotrodderhaag
    Bubba is building me a new distributor.. He said it will take care of my problems. Hope it gets here soon!
  22. hotrodderhaag
    hotrodderhaag
    Installed the gauge pod today, also I received my coil adapter kit . I'm going to try to stick with the factory helmet coil , so this kit will be a back up
  23. hotrodderhaag
    hotrodderhaag
    Still have not received any word that my dizzy is done . Looks like the Fourth of July isn't Happening. Wonderful.
    I shoved the car back into the corner of the garage and threw a cover over it.. Maybe she will see the highway next summer.
  24. Bigcheese327
    Bigcheese327
    :( Bummer.
  25. hotrodderhaag
    hotrodderhaag
    Dizzy will be here tues-weds..... Looks like ill be ready for the fourth. Hope it straightens it out.
  26. redzula
    redzula
    Awesome good luck
  27. There is a lubrication fitting by the drive pulley on the blower. Do you fill that with grease or oil? What is the required quan***y?
    Thanks
  28. hotrodderhaag
    hotrodderhaag
    That's not a lube fitting. That is a breather vent for the blower housing... It is supposed to have a round canister style breather with a screen in it..
  29. hotrodderhaag
    hotrodderhaag
    I tried to post a pic but its not letting me
  30. Hotrodmyk
    Hotrodmyk
    Glad your parts will be there. Have a great 4th. Going cruising myself.
