Think in terms of a clock face. You want to measure from 12 0'clock to 6. Measure straight across,just like 4 bolts. Odd numbers are awkward,even numbers are easy.
Maybe I'm completely off but most all six-lugs I've ever seen (all Chevy's and Toyotas, Datsuns) were the same size pattern. Is this true?
Jim, there are 3,maybe 4 6-hole patterns today. Dodge Dakota has one, Chevy trucks, Chevy Trailblazers are 3 different ones that come to mind. Charlie
And Ford has a 7 lug wheel instead of 8.... just to **** with wheel makers and owners who would like to swap what used to be universal one size fits all wheel brands..
Kirk, Unkl Ian, was right on, with his info.The best thing to remember with bolt or lug circles to remember,even number of lugs,measure straight across, and the bolt circle or pattern is what it measures,center to center.On uneven number of lugs,such as five,start with one lug,skip one,measure to the third lug,center to center, then add 1/4" to the dim. you came up with while measuring and thats your bolt circle or pattern.Example: a Ford 4 1/2" bolt cirle,has five lugs, it will measure, 4 1/4" when you measure,as stated above.Hope this helps and doesnt add to the confusion.
I need to learn how to measure a 6 lug. Mine are showing 6x6. Is this right? I was trying to find a common wheel I could bolt on this thing to roll it around. It's a 31 olds with 6 lug wood wheels. (oddly there is a 7th hole). Sorry to resurrect the dead with this thread.
needed to learn.. is what it should read. I needed to know how to measure the lug pattern, not how to use a ruler. And there is a difference in measuring even vs.odd lugs as I now know. I have a masters degree in technology education, not in measuring lug nut patterns. Thanks for the jerky response.
I think he has a valid point, and all of you who said something negative missed it. What is the bolt circle? Is it the circle on the outside of the studs? Is it the circle on the inside of the studs? Is it the circle through the middle of the studs? How would he know that there is not some trick to it? The automotive world is chock-a-block with stuff that makes no sense whatsoever to an outside observer. If you are not familiar with something, you need to ask questions. He did. Some of you chose to be real ****s about it. Way to rise above.
There are a few other on this site that need an at***ude adjustment...see signature Alway center to center of stud is the lug diameter, although inside edge of one hole to the outer side of the hole across on even lugged wheels will be the same measurement. Odd lug wheels are abit harder to measure, but it is the diameter of the lugs through their center. I would like to see this 7 lug wheel, pic?
I wish there was a thank you ****on on this forum, I would have hit it a few times. I'm getting 6x6. I want some wheels to roll this thing around on. DId some of these old 30's cars have a 6x6 wheel? When I look up lug patterns i'm not seeing that as an automotive pattern. Thanks to those trying to help me out here. BTW I'm a registered republican, have been since I was 18.
My 42 Chevy has 6x5.5 bolt pattern I believe You can find more info on http://www.carnut.com/specs/specs.html website they have a specs section that gives alot of info like bolt pattern wheel base and even engine displacment and H.P of the vehichles. I hope this will be of some help.
