55 Chevy Dual Master Cylinder
Discussion in 'The Hokey Ass Message Board' started by travj31, Jul 1, 2013.
  1. travj31
    travj31
    from Western PA
    Anyone know what is the best direct fit replacement for a factory single one? Don't want anything with a booster...
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    68-73 Chevelle, Nova, Camaro with manual drum brakes is one. One for a 70 Vette with manual brakes would be the other and more preferred choice as it has a larger reservoir if front disc's are a future plan. Both of these app's are 1" in bore as needed for your app.
  3. 40Standard
    40Standard
    from Indy
    are you going with disc on the front?
  4. 5CHERO8
    5CHERO8
    Wow, MANUAL drum brakes. Isn't that hard on the hands?
  5. Mercchev
    Mercchev
    Cl***ic Chevy does a kit with all you need. Relatively inexpensive, and all the parts are provided. Did my 56 Chevy a few years ago after a rear wheel cylinder blowout going downhill into traffic. Cheap insurance.
  6. travj31
    travj31
    from Western PA
    thanks for the info...
  7. judd55
    judd55
    from B.C.
    Here's a thread that should help, http://www.chevytalk.org/fusionbb/showtopic.php?tid/259644/ scroll down about half way for everything you'll need ..............read the entire thread as well, one fella had probs and another didn't.......YMMV :cool:
  8. henry's57bbwagon
    henry's57bbwagon
    I used a 71 Nova master, but with a booster but the bolt pattern is the same. Just about all Chevy masters fit all Chevy firewall mounting screws/ studs. Make sure you get one for drum/ drum.
