Hot Rods Heirloom Headache - 28 Hupmobile, Century 6
Discussion in 'The Hokey Ass Message Board' started by Chickenlegs, Feb 19, 2012.
  1. Chickenlegs
    Chickenlegs
    Ive been lurking for awhile while building my inherited 28 Hup. Im transforming it into a hotrod while trying to retain or enhance its look. Im using late model running gear and thought Id put out my feelers to whether its acceptable here or not.
    So, take that **** somewhere else? or Hell yeah lets see what ya got?
  2. safetymike1977
    safetymike1977
    Your car right? And when the hell you ever seen another hupmobile?
  3. barry wny
    barry wny
    Lets see it. If some paint is still on it I wouldn't bother with that. Stock wooden wheels if I remember right, maybe use driveline compatable with wires (rivera? caddy?) that will take jumbo tires. IMO a dignified car like that should remain unchanged outward apearances. Big & heavy enough need something with grunt that will fit the hood.
  4. dirt t
    dirt t
    Yes how about some pix's
  5. gump
    gump
    Pix agreed
  6. captainjunk#2
    captainjunk#2
    sounds pretty cool , post some photos of it ,
  7. Chickenlegs
    Chickenlegs
    Taken about 6yrs ago, before the tear down:
  8. safetymike1977
    safetymike1977
    Nice..... That would be fun to build...and the right amount of doors for the family.
  9. Chickenlegs
    Chickenlegs
    Old family pictures:
  10. Chickenlegs
    Chickenlegs
    Deforested the interior:
    Wood framing from the doors:
    Door skins sat in:
    Inside view of stripped doors:
  11. Chickenlegs
    Chickenlegs
    Pre-chop of 2":
  12. Chickenlegs
    Chickenlegs
  13. Chickenlegs
    Chickenlegs
    I bought a Buick Roadmaster and stripped it down. LT1 and auto. Retained the EFI. Rewired the motor for component location.
  14. Chickenlegs
    Chickenlegs
    Built motor and transmission mounts.
  15. Chickenlegs
    Chickenlegs
    Hung a column, mounted a master cylinder, built some pedals.
  16. Chickenlegs
    Chickenlegs
    Hung a ford 8.8 rear:
  17. Chickenlegs
    Chickenlegs
    I bought a Manex rear air from 'U yank it' which came out of a limo. The size is a little more than I could stuff under the dash in its entirety so I decided to cut a hole thru the firewall and recess the double fan motor. It moves some air.
  18. Chickenlegs
    Chickenlegs
    I got it tucked under the dash pretty well. The car orginally had wood sill plates, which Ive redone in steel. I think I will duct a vent into the steel sill plate since its hollow, to channel heat and air to the rear of the car.
    Built a cover.
  19. Chickenlegs
    Chickenlegs
    Built some brackets for the alt and a/c compressor so everything would fit under the hood:
  20. Chickenlegs
    Chickenlegs
    Built the intake:
  21. Chickenlegs
    Chickenlegs
    Started reframing the interior:
  22. Chickenlegs
    Chickenlegs
    Rear frame notched:
  23. Chickenlegs
    Chickenlegs
  24. dirt t
    dirt t
    Great work and well laid out. You have thought it out. what is the rear suspension?
    Keep posting.
  25. shivasdad
    shivasdad
    from Texas
    I love it. Very nice work and I think it will be a great cruiser.
  26. kyvetteman
    kyvetteman
    Nice work! You'll probably be the only one with a '28 Hup most anywhere you go!
  27. mcmopar
    mcmopar
    from Strum, wi
    Nice fab work. Looks like it will be a nice driver. Did the rear come out of a explorer?
  28. Chickenlegs
    Chickenlegs
    Rear is a ford 8.8 disc out of an explorer.
  29. HOTRODPRIMER
    HOTRODPRIMER
    To be honest I was afraid to open this thread because I expected to see a fairly rare and unique car so drastically cut up that it would be a far cry from what it originally started life as.
    The work is first cl*** and it is evident that a lot of thought was given in the Hups resurrection,,I believe the previous owner would approve. HRP
  30. Nice Hup ! Mines a 33.
