Starter issues- I think...
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by brooksinc1976, Jul 3, 2013.
  1. brooksinc1976
    brooksinc1976
    from P-Town
    Got a '56 chevy truck with a camaro clip and a 454 that has mid length headers. The headers are REAL close to my starter. When I go to start it wants to drag and barely turn over. I have checked the batt and its good. If I put jumper cables on it it helps. Some. This issue is present weather the eng is cold (I live in houston-95 today) or if its warmed up. Suggestions??? My buddy recommended a Jeggs compact high torque starter and heat wrap. Sounds good but I don't want to just through parts at the problem.
  2. dad-bud
    dad-bud
    Seriously? You've posted 58 times, and you come here to the Introductions page to ask about a starter problem?
    Dude, head over to the Message Board
  3. brooksinc1976
    brooksinc1976
    from P-Town
    Well I guess on the app I didn't notice that
  4. 59Apachegail
    59Apachegail
    from New York
    Check your ground on the block it may be loose
  5. brooksinc1976
    brooksinc1976
    from P-Town
    Nope it's tight
  6. D.B. Cooper
    D.B. Cooper
    from SD
    check the brushes and clean the commutator.
