Projects 1940s Model A Sport Coupe Build Thread
Discussion in 'The Hokey Ass Message Board' started by mramc1, Nov 28, 2011.
  1. mramc1
    mramc1
    Not working fast enough for some folks so time to slow it down and put the brakes on!
    '39-'41 style.
    Here's to hoping the foreign wheel cylinders don't leak!
    Then some lines. The new nickel/copper/alloy stuff is awesome to work with!
    Just waiting to turn my drums a little bit and then can put new seals in and put them back on.
  2. mramc1
    mramc1
    Motor work! Got the timing belt changed. Fuel pump aux shaft swapped in, new seals.
    Nice coat of Ford engine green.
    Bolted up the new clutch and pressure plate.
    In she goes!
    Bam!
    Now I'm ready to finish the clutch linkage and bleed the brakes.
    kiwijeff likes this.
  3. rusty truck
    rusty truck
    from rochester
  4. mramc1
    mramc1
    Thanks, Bro!
  5. crminal
    crminal
    Ya know, least its a 4 from Ford and it just looks good in there.
  6. mramc1
    mramc1
    This build is really exhausting, maybe a new muffler will help! Built the exhaust system over the weekend. Started with a long Smitty's muffler.
    Next started messing with pieces of pipe to the manifold.
    Then I wanted a lake pipe I could uncork when needed so...
    I used cat flange and pipe off a newer GM econobox to make the lake pipe. The 3-bolt flange was perfect. Then I used the other side of flange, blanked off inside, for a dummy tip.
    And then the tailpipe.
    Little bit of welding, grinding, and then a coat of heat paint and bam!
    Outside in the sun one of the last times before the body goes back on.
  7. ESGEE
    ESGEE
    from Sweden
    Looking good, and out in the in the sun and all...
  8. firepilot
    firepilot
    This is by far my favorite build, can't wait to see it all together.
  9. Tnomoldw
    Tnomoldw
    :)Looking good ,Josh!:cool::D
  10. mramc1
    mramc1
    So this weekend got the bottom of the body painted and undercoated.
    Then filled and painted the firewall.
    Then got the body back on the frame!!
    Spent the rest of the weekend bolting down, adjusting pedals, fitting floor boards, etc. Also started to mud all the Frankenstein monster-like seams in the roof.
  11. Mentalstates
    Mentalstates
  12. Fenders
    Fenders
    Maybe it's just the photo angle -- but turn the front wheels lock to lock and make sure the brake hoses are long enough.
    Nice build !!
  13. mramc1
    mramc1
    There is plenty of slack at full lock. That was one of the first things I checked when fitting things up. Thanks for the heads up.
  14. thunderbirdesq
    thunderbirdesq
    gettin there! Nice!
  15. fab32
    fab32
    WOW!!! I can't believe the number of hours you must have in this project. Thank you for taking the time to do***ent the process. A young guy (or anyone for that matter) would do well to read all of the details of this thread and see the problem solving you came up with for each detail.
    I predict that there will be a lot more builds that follow the general theme of your car as gas gets more expensive and the desire to put major miles on a hot rod clash with the amount of $$$'s available to enjoy our hobby/obsession. I remember a similar scenerio happening during the first gas crunch that our country went through. Hot rodders started bragging about the MPG they were getting instead of the horse power/speed.
    Frank
  16. mramc1
    mramc1
    Thanks, I try to build and keep it simple with mostly hand tools and a welder. I hate doing body work and washing so I like primered cars. I might not build the coolest, prettiest, or fastest stuff, but at least I can say I did 100% of the work and that my cars are reliable drivers that get used every day.
  17. crminal
    crminal
    I like the way you think!
  18. Tnomoldw
    Tnomoldw
    :)Right on Josh!:cool::D
  19. Flybyford
    Flybyford
    from NE Ohio
    Nice work! Cool thing about the 2.3L it could always be uprgraded later for more power.
  20. mramc1
    mramc1
    Does this mean I'm officially part of the club?
    Mash the loud pedal! Time to build the throttle linkage. I started with a way rusty s**** throttle I cut out of '39 pickup laid on it's side for about 50 years in the junkyard.
    Then I did some math and welded an arm on the left of the shaft.
    I'm using a Holley 2300 series carb that is supposed to be 310 cfm. When I tune the jets I think it will be an economical little carb.
    Used some garbage picked rod ends and sleaves to make a linkage. The pedal feel is great, there's no binding, and it's simple. All I need to do is grommet the hole and I'll be set.
  21. mramc1
    mramc1
    Had to update my Photobucket account so pics are available again.
  22. chevy54man
    chevy54man
    from NC
    Great work on an awesome car!
  23. 41 C28
    41 C28
    Great build thread. I'm watching.
  24. mramc1
    mramc1
    This 4th I spent America's birthday building a hot rod! I worked on a bunch of odds and ends then made new floor boards. I garbage picked a mint sheet of 3/4" treated plywood so I started measuring and cutting.
    Then set the gas tank in and made a trunk fire wall.
    Seeing how the spare fits.
    Trying to finish for a local show on July 28th. We'll see how it goes!
  25. simplestone
    simplestone
    Looks nice. But, if you haven't already, you might want to verify that marine plywood won't react in a negative way where it contacts the metal. I hear that pressure treated lumber shouldn't be used in the bed of pickup trucks for this reason.
    Not positive this is true, and I don't know whether marine plywood is treated differently than the lumber, but just thought I'd p*** it on.
    I'm loving your build, though!
  26. lorodz
    lorodz
    Looking good
  27. 101Scout
    101Scout
    Wow! I'm in awe! Nice job Josh, she's a beaut. I love your home grown solutions and fabrication. I'm still learning, but hoping to get there some day!
  28. brokenspoke
    brokenspoke
    I have heard that the new treatment is salt water infused????
  29. mramc1
    mramc1
    The wood is now painted black with a heavy coat of oil base enamel both sides so. I think this may stem from people using non-coated steel screws when building treated decks and having the screws rust and corrode after a few years. I'm not worried about this happening in a car floor that isn't exposed to constant rain/dew/weather.
  30. mramc1
    mramc1
    Thanks! Nothing special used here, just hand tools, welder, grinder and a lot of manual labor.
    brEad likes this.
