1956/2012 : A hot rod then / A hot rod again
Discussion in 'The Hokey Ass Message Board' started by Flop, May 20, 2012.
  1. Flop
    Flop
    thanks hasty!!
    well the subframe is pretty much finished up ...minus a few brackets ... thats next !!:):)
    well i got ahold of a nice henry bracket that rivets to the curved panel and bolts through the spare tire holder!
    sometimes you have to use some odd pieces to align the panels !!
    and the curved piece in place with the bracket riveted on
    the whole deal !!
  2. I think you post too much!!! :eek: Hahaha! :D
    Good thread to visit during my next Roadster build
  3. lewk
    lewk
    from Mt
    Awesome thread and awesome work. I'm learning a ton just sitting on the sideline!
  4. 28-31
    28-31
    Tom,
    I've finally pulled the ch***is out of winter storage and have started the rebuild. Hopefully I'll have it done (or at least presentable) by the time you're ready to finish mount the body. We'll see...
    When do you think you'll start mounting the body panels to the subframe (which looks great, by the way!) ?
    -Jeff
  5. 29ToyA
    29ToyA
    Wow
    Outstanding work!
  6. 36 ROKIT
    36 ROKIT
    Double WOW; a real piece of metal sculpture. Too nice to cover up!
  7. Krash
    Krash
    from Cleveland
    Amazing craftsmanship!
  8. slammed
    slammed
    Creating a quality build from shards of o l d pieces of bent, cracked rusted and booger'd metal is amazing. You are, Mr. Amazing.
  9. Flop
    Flop
    thanks everyone !! hopefully off to the body shop before the end of the month,then back on the frame for the paint job then final ***embly !
    into epoxy primer
    the curved panel isnt bolted down thats why the lip is in the air
    all one color !
    28-31
    It's nice to see it all finally coming together -- amazing work!
  11. Flop
    Flop
    thanks Jeff!!
    stanchions gotta fit right ! kinda look sloppy here
    with a little work
    gaps gaps gaps
  12. rustednutz
    rustednutz
    from tulsa, ok
    Awesome work, Flop. I'm still gathering parts for my 31 coupe and was wondering where you got your subrails and front extensions that tie into the firewall.
  13. Flop
    Flop
    thanks rusted ! any model a place sells them . but i get all my stuff from snyders since it is so close to me .
    br*** stanchion?
    a little different compared to the steel one on the drivers side and seems to a little worse off in the fit dept .
    setting a few last rivets
    a single color and its starting to resemble a car!
  14. Flop
    Flop
    thanks cactus!!!
    so i did a little tapping to get a better fit of the corner...she was thin !
    also trimmed a little more to get a nicer fit
    :eek::eek:
    moving along now !
  15. 117harv
    117harv
    Great motivation for us and always a good read....BEAUTIFUL work as usual.
  16. thunderbirdesq
    thunderbirdesq
    My old restorer buddy said he has often found both steel and br*** substanchions on the same car over the years. Looks great man!
  17. 48fordnut
    48fordnut
    I have one of each on a 31 cowl.Looks original,but who knows.
  18. FlynBrian
    FlynBrian
    Awesome job your doing, looking Good!
  19. ty johnson
    ty johnson
    Your awesome! Great craftsmanship.
  20. 28-31
    28-31
    You make the repairs look effortless -- really great work.
    I can't wait to see it with some color on it -- although that means I actually have to pick a color!
  21. Flop
    Flop
    thanks 117 !
    thunderbird we are now looking for another steel stanchion. the br*** one has a horrible fit . very weird .
    interesting 48ford!!
    thanks Brian!
    thank you ty !!
    better get picking Jeff
    moving along!!
    time to fight the rumble lid ! :rolleyes::rolleyes::eek::eek:
  22. Mart
    Mart
    Great work, Flop.
    Mart.
  23. druids62
    druids62
    Awesome work Mr. Flop.
  24. Flop
    Flop
    thanks Mart ! Thanks druids!
    well it took a little battling but it fit in its hole relatively well.
  25. Flop
    Flop
    brooville ,brattons and 31ster here on the hamb came through with the parts!!
    getting everything lined up
    they are not the ovals ford had in them but they served their purpose. well at least the top and bottom holes
    dash rail . had a pretty big dent so that came back off
    curved panel with rumble stops installed
    package tray sitting in place . also borrowed some door handles to set the holes and d nuts!
    also faced the bolts to remove marking so they look more original .
    does anyone know why Henry used some square nuts and some regular nuts ? or some square nuts been replaced?
  26. Flop
    Flop
    frames here!!
    frame is within an 1/8th o an inch of square and no noticeable sag !
    a few tiny messes
    and some screws
    first time on a frame and completely together is 40 plus years !!
    cleaning day with the giant was today !!
    28-31
    Looks great on a frame, Tom! -- can't wait to get this thing back on wheels and tires.
  28. jimz31
    jimz31
    from PA
    Awesome work Tom!!
    You have brought it a long way!!
    That's a good lookin helper you have there! :)
  29. shane85
    shane85
    dude you rule!!!
