Sunday Models 7/7/13
Discussion in 'The Hokey Ass Message Board' started by 30FordNerd, Jul 7, 2013.
  1. froghawk
    froghawk
    Very impressive! I'd love to learn to work in metal.
  2. big duece
    big duece
    from kansas
    Ognib, what are you using for header material? Solid alum. rod? These sbc were made with solid br*** rod, and soldiered together. I found an inner race of a roller bearing the had the same radi as the br*** rod, and used it as a die to bend with. Both engine parts are 1/8.
  3. Deuces
    Deuces
    But I am...:eek::eek::eek:
    I'll get started this week on something...
    Been working allot lately...:rolleyes:
  4. Deuces
    Deuces
    Nice br*** work!!!!...:)
  5. Ognib
    Ognib
    from Mo
    I used solid core silver bearing solder.
    Bends nice & smoothly & holds it's shape well while I handle the engine for doing other things.
    Your set looks great.
  6. philo426
    philo426
    I had to make a set of headers for my current project.I used one conductor wire and it worked well. [​IMG]
  7. musclecars
    musclecars
    I don't post here as much as I like to,but here are a couple in progress projects fresh from the paint booth.Hey John,I believe you may have seen these since I know you post on Spotlights Board.Love your building style as well.
    Revell '48 Ford Convertible
    AMT '36 Ford
  8. Church Key
    Church Key
    EXCELLENT work... what kind of soldering gun are you useing? I use to do a lot of slot cars in br*** and a few static models. Working with br*** can be both fun and frustrating.
  9. Ognib
    Ognib
    from Mo
    Whipped up an aluminum distributor this afternoon & got it fitted to the front cover.
  10. 30FordNerd
    30FordNerd
    Some more stuff from me is this Porsche kustom with filled in front lights and rear lights as well, It will have a small block chev. Second is this kustom Henry J.
  11. Hacker Joe
    Hacker Joe
    I use a 60 watt iron from radio shack, then 60/40 solder with lucky bobs flux. I would much rather use metal than plastic. I learned soldering from doing slot cars too.
  12. 30FordNerd
    30FordNerd
  13. Offset
    Offset
    from Canada
    Some great models this week folks. I really like the dragster frame, did you work from plans or just what "looked right" because it does.
    Nice.
  14. Ognib
    Ognib
    from Mo
    New distributor mocked up on engine.
  15. kenmo
    kenmo
    Wow....damn nice work....:)
  16. 54rat210
    54rat210
    What scale did u build this for?? I like it idea for fabricating headers:D
  17. Old Sprinter
    Old Sprinter
    Ognib; I think you're more than ready to scratch build a whole car. You have done some great work and I'd love to see you build one from nothing but sheets and tubing.
  18. Ognib
    Ognib
    from Mo
    Kenmo, thank you very much.
    Sprinter, after having viewed several of your builds, I feel honored by your post.
  19. philo426
    philo426
  20. philo426
    philo426
    These fender well headers are not easy! [​IMG]
  21. Hacker Joe
    Hacker Joe
    I scaled up some pictures to get it close but it is more "if it looks right, its right"
    I have the ch***is painted and the front end done, I just need to take some pics
  22. CrazyDog
    CrazyDog
    from Colorado
    Here is my pics of my 66 Mustang and last winters project
  23. JimC
    JimC
    from W.C.,Mo.
    Crazy Dog, that is alright!
  24. CrazyDog
    CrazyDog
    from Colorado
    JimC
    I made a model before I restored her, rust holes and all, and wanted to do one when she was finished, but had a terrible time finding a model. Seems they don't make 65/66 kits anymore.
    Come on this is the car the " Pony Car" movement was named for.
  25. wojojo
    wojojo
    Have you tried fleabay?
  26. CrazyDog
    CrazyDog
    from Colorado
    I finally found one on Amazon. Real cool. Restomod kit. You could build it bone stock, restomod or full out drag. Had a couple engines, stock tires/wheels to skinny/slicks. Had tires and wheels almost like my coupe.
  27. you can walk into any hobby shop ,hobby lobby etc and buy a 66 mustang coupe from round 2 models (original amt kit) in 1/25 scale
  28. philo426
    philo426
    I cut a section out of an old antenna ,slightly flattened it and made a cool header cap[​IMG].
  29. Deuces
    Deuces
    Jim has one for sale and many others...
    www.jimnohio.com
    Look in the muscle car section...;)
  30. 30FordNerd
    30FordNerd
    58 posts for Sunday models is a great job, biggest one in a long time.
