too much radiator pressure
Discussion in 'The Hokey Ass Message Board' started by karilane, Jun 30, 2013.
  1. karilane
    karilane
    i have a 34 dodge truck with a 350 small block mild cam. problem motor does not over heat but pushes coolant out of over flow tank only at higher rpms. for instance im driving down the road at 60 mph 2000 rpms i get on it say 3000 rpms to p*** a car . after i let off it blows coolant out over flow. temp dosent get over 180 degrees. i have put a 7lbs 11lbs and a 16lbs radiator caps on all with same problem. any ideas? i have also checked the oil no coolant in it its nice and clean.
  2. F&J
    F&J
    just a guess, does the lower rad hose have a coiled wire in it, to keep it from ****ing flat? Cheap to try it.
  3. karilane
    karilane
    yes I had put one in just to avoid a problem. thanks though
  4. mustang6147
    mustang6147
    from Kent, Ohio
    Is it a down flow radiator, or cross flow?
    Down flow radiators top tank acts like an expansion tank, and will spew coolant out until it get to its right level.... Sp if you top the tank off it will do what your describing until it rests about the half way mark.... that's half way the top tank, not the radiator...
  5. karilane
    karilane
    its a down flow radiator and it will push out about half a gallon. the rad. size is 24"x30"
  6. karilane
    karilane
    does this sound right?
  7. GassersGarage
    GassersGarage
    Do you have an over flow tank?
  8. karilane
    karilane
    yes i do and it will hold about a quart or alittle more
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Is there a problem with the radiator nech where the cap fits? ,preventing cap from seating correctly and holding pressure? There are 2 neck depths 1" and the more common 3/4" ,cap match the neck?
  10. karilane
    karilane
    wasnt aware of that one but ill check it out thanks
  11. G-son
    G-son
    from Sweden
    Leaking head gasket? At high cylinder pressures exhaust gets pushed into the cooling system, and it has to go somewhere... Had a OT car do that, just fine when driving slow, but put the pedal to the metal and have the entire engine bay sprayed with coolant from the radiator overflow.
  12. 57 HEAP
    57 HEAP
    Just my 2c.
    Sounds like a fluid level problem to me.
    What difference does pressure make? The fluid level is the same. In order for the coolant to exit the system it must get past the cap. As it heats up, the coolant expands, when it gets to the cap, it flows out. If you keep refilling the system it will keep overflowing.
    I have a down flow radiator. When I first started driving the car, I filled the tank to the top. Once hot, coolant leaked out. But I didn't add any and the system has not leaked since. The radiator is not "full", but the car does not over heat either.
  13. elba
    elba
    Don't fill the radiator to the top. Leave an inch or so for expansion. Give it a try.
  14. Jalopy Joker
    Jalopy Joker
    how full do you keep over flow tank before start up? what mix of coolant? what type of fan, if electric pusher/puller with shroud? high speed water pump? use byp*** hose from intake manifold to water pump? condition/pressure radiator cap? run a hood?
  15. VoodooTwin
    VoodooTwin
    from Noo Yawk
  16. hotroddon
    hotroddon
    I would say that the cap is the wrong style and is not sealing to the radiator, or the radiator neck is damaged and not allowing it to seal.
  17. karilane
    karilane
    so tonight i checked radiator cap for fitment. all good there but bought a new rad. cap 22lbs and installed. toped off rad. and drove yes i lost some fluid at first but only about a quart . i guess we will see what happens!
  18. I've run in to the cap issue as well. Exact same problem as you describe. New rad and new cap. Cap didn't seal. Replaced the cap and is fine.
  19. Try a AC RC 33 made for a recovery tank .Once avery thing is equilizad it will be normal just check your tank level
  20. karilane
    karilane
    does the recovery tank need to be presurized for fluid to be ****ed back into rad. ?
  21. No. It does not.
  22. LOST ANGEL
    LOST ANGEL
    Quit topping the fluid!! Let the thing seek it's level, and LEAVE IT ALONE. Use a puke can and watch your temp gauge. After it quits spitting out the excess, all will be fine.-MIKE
  23. VoodooTwin
    VoodooTwin
    from Noo Yawk
    No. The tank catches the coolant that is released by the cap when it expands beyond the capacity of the radiator due to heat. When the coolant in the radiator cools off, it contracts and creates a vacuum, which ****s the coolant from the puke tank back into the radiator. Make sure the overflow hose is submersed in fluid, to eliminate an air gap, otherwise all it will **** is air.
  24. mcmopar
    mcmopar
    from Strum, wi
    Is fluid going back into the over flow tank? I had mud wasps pack mud into my over flow hose when it was off putting in a new water pump. When I put everything back together it, would spit coolant out. After replacing pump again, cap, hoses, and having radiator cleaned, a friend asked if I checked the over flow hose. Who would of thought that it could have happened. Good luck, I am now working on a 37 Dodge, and hoping for no problems, but we know that ain't going to happen.
  25. chaddilac
    chaddilac
    If it's a stainless overflow tank like everyone runs, make sure you have the hose on the right inlet and not the outlet.
  26. Streight8
    Streight8
    Being paranoid, I am kind of with G-Son on this, leaking head gasket or similiar. Have you tried running it without the cap on the rad and observing if you see some bubbles. On a reall small leak you won't always see oil/water cross contamination or even have any issues until the car starts running consistantly to the higher side of its temperature range.
    I did have one wierd problem years ago. I had a seal leak on the water pump shaft. It would pressure up the system when running and push water out the overflow (pre catch can era) and not leak at the pump, then when you shut the car off the pump would leak a minor amount from the small hole on the shaft casting until the pressure dropped then stop leaking.
  27. karilane
    karilane
    okay so i have gone up to a 22lbs rad cap and thought problem was fixed. wrong!!! so tonight put a pressure tester on rad. pumped it up to 22 lbs and it slowly bleds off. so next i pulled all spark plugs and numb 6 was wet. next i pulled the head and checked gaskets. all seamed to be good, but on inspection noticed more like oil in the intake runner for the number 6 cylinder. does this sound right for a cracked head or could it be the intake.
  28. Dane
    Dane
    from Soquel, CA
    That's your problem. You need a bigger overflow or live with the rad not being full to the top.
  29. mustang6147
    mustang6147
    from Kent, Ohio
    The tank will never stay full. Its an expansion area. top it off, and it will puke antifreeze out till it settles...
    If you have a cracked head, you would see air bubbles coming out while running at operating temps with the cap off.... But you still have to let the fluid level settle....
    Normal range is about an inch over core tubes.... Not full
  30. karilane
    karilane
    machine shop confirmed that i had a cracked head on the number six cylinder. the crack was between the valves causing me to have to much preasure in radiator. thanks for all the feed back
