Rust removal.......the miracle of molasses!
Discussion in 'The Hokey Ass Message Board' started by evintho, Feb 5, 2011.
  1. Jimbo17
    Jimbo17
    One question what do you do with the mol***es when when you are finished using it?
    How do you get rid of it and where?
    Looks like it works great. Jimbo
  2. Kiwi 4d
    Kiwi 4d
    It's all organic so it can go down the drain or water the yard sparingly.and possibly flush with fresh water after cos it's sticky stuff.
  3. 56PonchoWagon
    56PonchoWagon
    from El Paso TX
    That is the neatest thing i have heard in a while.. going to save me a ton of money... so long Evapo Rust!
  4. rocksolidnate
    rocksolidnate
    from Viroqua Wi
    Going to have to use this one
  5. Moon Rocket
    Moon Rocket
    from GA
    I've been soaking mine in Honey for over 30 years, haven't noticed any rust on it yet! ;)
  6. evintho
    evintho
    1) Ya gotta hose off the film that's left on the metal.
    2) Just like any liquid make sure you hose it all out and blow it out completely w/air afterwards.
    3) It didn't harm the original paint. See #2.
    I just unscrewed the back panel of the tank and let it drain out on the ground. Didn't attract any critters at all.
  7. 4rod
    4rod
    I bet it would clean out a gas tank too...That is awesome...
  8. whats the lifespan of the mixture once it is used first time?
    Is it a pitch it out- start over situation or reuseable to a certain extent?
  9. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Thanks for the info- never heard of that one
  10. just Mike
    just Mike
    I've been using the same batch in constant use for over two years now! Takes up to three weeks to derust parts now.Was quicker in the beginning.
  11. shooter6
    shooter6
    does anyone know if You use a pump & pvc to make a shower, if the mol***es will still work? Im thinking a sump, withe a strong pond pump, to spray the mixture onto a complete car.
  12. Amazing, never knew.
  13. jkski
    jkski
    i have a question after awhile a black skum forms on the surface i have been using a piece of cheese cloth on a homemade to clean it out,is that skum the rust or some of paint that still on the part
  14. Jay Tyrrell
    Jay Tyrrell
    This peeks my interest.
    Jay
  15. HOTRODPRIMER
    HOTRODPRIMER
    Mole ***es!:D HRP
  16. Speedy Canuck
    Speedy Canuck
    For the most part, mol***es won't take the paint off of parts. (At least, I've never had my concentration of mol***es high enough for that to happen).
    The skim that develops on top of the mol***es bath is mold. Probably some dirt and rust mixed in, but mainly mold.
  17. morac41
    morac41
    Hi ... If you want to speed the process up you can hang a couple a pipes in opposite corners and connect 12v battery charger on low...you must keep inspecting the parts every couple of hours or they will disintergrate....I used this method on my T parts (my avatar) took less than a day for same results as 6-10 days just laying in the bath......this is probally safer if you cant watch the derusting processs.....
  18. morac41
    morac41
    Hi There is a photo of the cowl in "my albums" ...Track T ... have a look there is a photo with the cowl ..photo called ..setting up...this was before I dumped it in the tank .... another where the cowl is ***embled with doors and tub sections after being in the tank....Cheers Doug
  19. T27owner
    T27owner
    from Nebraska
    I"m a believer Been soaking my car for 1 1/2 weeks and it takes rust and it blasts off with a pressure washer. But it flashes quick and you need to get something on it quick. Bought WD 40 in a fog can hit it wipe it down, then steel wool and a rag. the smellier it get the better it works. And the deer like it too! The gas lid is on my spare cowl, its in the tank along with 4 '27 wires.
  20. dragsled
    dragsled
    from Panama IA
    Aren't you gonna post pics of your handy work:D Tim Jones
  21. T27owner
    T27owner
    from Nebraska
    picture:rolleyes:
  22. morepwr
    morepwr
    from socal
    Well I'll be. I had no idea about mol***es!
  23. Rob68
    Rob68
    ...x2
  24. NORSON
    NORSON
    Heres my setup. I have a 300 gal. stock tank. I fill it with 10 - 3 1/2 gal pails of mol***es @ $10 each and top it off with water. I can get 3 or 4 loads of parts cleaned before it starts to loose it's effectiveness. When I pull the parts from the tank, I hose them off with water (a pressure washer would be better) then brush them with a mix of 3 to 1 of prep and etch (from home depot). I also use a weed killer sprayer to spay the etch into cavities. The etch kills the flash rust and protects the parts from rusting. Etch is used to prepare a surface for painting. The tank would be better if it was square. 48"x60" by three foot tall would be about right. I've been doing this for about three years. all I know I learned from Jimmy B.
    Norm
  25. NORSON
    NORSON
    An additional note. I wash the parts off on the gr*** in my backyard as well as applying the prep and etch. I drain the used fluid into the sewer. It doesn't kill the gr*** or the dogs. When it gets old and starts to turn black it starts to get ripe then it time to change it. Norm
  26. tfeverfred
    tfeverfred
    "I drain the used fluid into the sewer."
    Is that safe for the environment? Is dumping the used mixture, something that would need to be checked on with the EPA or whomever?
  27. mcmopar
    mcmopar
    from Strum, wi
    I think that I just figured out how to get the rust off of my 37 dodge box. Has anyone ran into any problems with this years down the road, with paint sticking?
  28. Speedy Canuck
    Speedy Canuck
    Nope. Everything you are dumping is natural and organic. The two main things being rust, and mol***es.
    If you spread the mol***es around the gardens or bare patches of gr***, it helps things grow. Though, it seems to kill the gr*** if you dump the whole bucket of mol***es on one patch.
    Dump it on your compost pile if you have one to help with bacteria growth and decomposition.
    Mol***es is used in animal feed, as well as human consumption.
  29. Rattle Trap
    Rattle Trap
    Beet juice will do the same job. Though the mol***es is cheaper and easier to find.
  30. bambbrose
    bambbrose
    from So. Utah
    Has anyone tried this in those plastic 55 gallon drums? Any reason to think it would degrade the drum? How about metal 55 gal drums?
