Y block timing?
Discussion in 'The Hokey Ass Message Board' started by c334charlie, Jul 9, 2013.
  1. c334charlie
    c334charlie
    what should we run for total advance and what rpm all in this is a 312 y block with a lathem blower not a lot of boost. just crusing marloy dist . no vac. advance.
  2. leadsled
    leadsled
    seems like it should be about 8-10 initial. what cam are you running?
  3. c334charlie
    c334charlie
    I need to find what y block people use for total and when all in rpm.
  4. RB35
    RB35
  5. dana barlow
    dana barlow
    from Miami Fla.
    32 to 34* total on todays gas
  6. Ole don
    Ole don
    All in at 2200, 36 degrees. Under pressure? Check with Bubba, or McTim here.
  7. c334charlie
    c334charlie
    so not any different than sbc. I wondered since flatheads are so different if y blocks wold be?
