I am thinking of putting the Edelbrock tripower with the 94`s on my Ford 5.0 more for the look then performance. No luck finding any threads on this. Anyone have this on their car?
Is everyone asleep?! If you want the look over performance, then block off the outer carbs and then you will get simplicity in dealing with 1 carb working, and good gas mileage.
Have that set up on my 57. Not a 5.0 but a yblock. My suggestion is to set the engine up with a stock intake/carb set up & get to run as good as you can before you go to the 3x2 intake. Then I would install the 3x2 intake & block off the end carbs & get that to run its best before I ran all 3 carbs. My .02
I have this setup on the 283 I am putting in my '40 pickup.Get the angle cut ****erflies for the two end carbs, Speedway sells them, then fit them tightly so that you cannot see any light at the contact points. Use progressive linkage and you should be good to go.
Hb32. I'm hoping to do the same thing with my 37 zephyr, it has a 5.0 with fuel injection, wish the v12 was there but it long gone so I going to try to make what I have a little more old school. The edelbrock set up seems to be the ticket. But I can fine little info on the swap, the best info has been on mustang sites converting fuel injection to 4 barell carb. Good luck
I started off with the EFI but gave up while trying to clean up a Ford Racing harness and used a Edelbrock F4B along with a Holley 650dp. It runs fairly well. I also swapped the cam for an E303, with a set of Edelbrock performer heads. Not really the look I want hence the thread looking for more info. As you are finding out as well, I can`t find anyone using it.
I'm using original Holley 7RT model carbs. Plenty of parts are available for Holley 94 carbs. Vintage Speed carries parts you might need but some guys on here have had trouble dealing with them. I haven't myself.
I have the manifold coming but have not pulled the trigger on carbs. Lots of reading on here and in other places. I have been in contact with several carb rebuilders on a complete set up for my 5.0 including linkage with the necessary provisions completed for a tri power. What should I be looking for carb wise as in model # and pit falls to avoid, questions to ask, recommended rebuilder? I know the performance won`t be the same as my 650 DP and F4b manifold. Thanks and want to do it right the first time.
Managed to get it running this afternoon. http://www.youtube.com/watch?v=QkdfFi_SqjI&feature=youtu.be Had some initial problems with leakage and timing but it appears to run really nice on the primary. I still have to dial in the outers.
If you have not already do so, search the HAMB for "Holly 94 info and "links to Holly 94 technical info". Running progressive linkage requires the end carbs to be modified and a very different set up than running all three together. Good luck.
End carbs have the idle circuits and chokes removed if this is what you are talking about? Carbs were built by ****ster here on the HAMB for progressive linkage. I also modified the primary for timed vacuum using the Holley 94 technical info and it is working properly.
I was going to comment till I read that last post about using progressive linkage. There is no way you will ever know how well that manifold could have performed with straight linkage and 3 48's.
"End carbs have the idle circuits and chokes removed if this is what you are talking about? Carbs were built by ****ster here on the HAMB for progressive linkage. I also modified the primary for timed vacuum using the Holley 94 technical info and it is working properly." Yes, the idle circuit block offs was what prompted my comments. Your previous posts did not give much in the way of details as to what you had done or the extent of your research. Since you requested "more info", I attempted to add some. ****ster will get you set up properly. Seems like you are on top of it.<!-- / message --><!-- sig -->
