1953 Dodge firing order?
Discussion in 'The Hokey Ass Message Board' started by thndrc6kn, Sep 8, 2011.
  1. thndrc6kn
    thndrc6kn
    Hi again everyone,
    Does anybody know where I might find a diagram of the firing order for a 230 flathead? I came across one online recently and have been unable to retrace my steps. Any ***istance would be greatly appreciated.
    Thank you,
    Thomas
  2. RichFox
    RichFox
  3. cowboy1
    cowboy1
    from Austin TX
    That was quick! lol
  4. thndrc6kn
    thndrc6kn
    you guys all rock! thanks again.
    Thomas
  5. squirrel
    many of us have it embedded in our brain stem.
  6. RichFox
    RichFox
    I suppose that somewhere there is a straight six thats not 153624. But I haven't seen it. I do remember Army mechanics school when the instructor burned it into my mind. "I got a date for one of you guys but there is one bad thing. She is 15" Noooo. "OK. She has a sister. But the bad news with her is she's 36" Noooo. All right than, they have another sister and she is 24" Yeaaaaah
  7. 53 hemi
    53 hemi
    Just in case you wanted to see it written in stone.
  8. ClayMart
    ClayMart
  9. thndrc6kn
    thndrc6kn
    Ok, so we got the carb rebuilt, the spark plugs gapped, and the firing order proper. She popped really good a couple times and then ran about 2 cycles then we couldnt seem to get a repeat. We tried a couple more times till the battery weakened and then called it a night. Shes almost there, the fire out the rusted off tailpipe was nice. Tomorrow we are gonna try and change the tire if we can get these 1 1/2 lugs to loosen on the driver front. Then we are gonna try pulling it around the feild to see if we can get a compression start. Of course, any suggestions or advice is always welcome and appreciated.
    Thanks,
    Thomas
  10. mustangsix
    mustangsix
    In some of my old Jag manuals, #1 is the rearmost cylinder (what I normally think of as #6) on an XK. If you just rename them front to rear, it comes out the same.
    V6's get tricky, however.
  11. RichFox
    RichFox
    Look out foor left hand lugs.
  12. Frankie47
    Frankie47
    from omaha ne.
    Left hand threads on the driver's side.........
  13. thndrc6kn
    thndrc6kn
    Thanks again everyone.
    Thomas
  14. thndrc6kn
    thndrc6kn
    What blasting media would be recommended for rust removal on the body of this beauty? Beads? Walnut? Plastic? Or Sand? Or Aluminu Oxide?
    Thanks,
    Thomas
  15. RodStRace
    RodStRace
    If it's popping and you set the points along with the correct firing order, it's probably timing. Do a search for 'dead timing' to get it close.
    As said, left hand left side.
    Blasting has various issues. Do a search here for lots of threads and comments.
    For those that whine about sending someone out to search, understand that not many people are going to open a thread on firing orders to get the best opinions on blasting.
  16. southerncad
    southerncad
    And don't forget, that your Dodge is 6 Volt... Positive ground:eek:
    And that flathead will sound like it IS going to start if you have it hooked up with a Negative ground....don't ask how I know:D
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    RichFox>>>Look out foor left hand lugs.>>>
    Frankie47>>>Left hand threads on the driver's side>>>
    Maybe LH on the drivers side from the factory. But not necessarily if it's ever had the drums pulled by a dyslexic mechanic. Replace the LH lugs with RH before they start getting broken off.
    Jack E/NJ
  18. RichFox
    RichFox
    That's why we sugested he look out for them. They might be there and he should be aware of the possability. Just "Look out"
  19. thndrc6kn
    thndrc6kn
    Well the tire is still on. We did get it to fire a lot better today though. She ran for about 10 seconds, she was ramping up and then lost it. Gonna try getting that tire off again tomorrow, as well as turning her over again with a fresh charge on the battery. It just seems like the cranking amps arent quite enough, but then again this is a whole new game for me. Hoping tomorrow ends up with more smoke out the tailpipe than we got today. SO CLOSE I can taste, smell, and feel it. Thanks again all for your advice, it all weighs equally on me.
    Thanks,
    Thomas
  20. Frankie47
    Frankie47
    from omaha ne.
    why change them.......you can't remember L stands for left?
  21. squarebird352
    squarebird352
    Throw a gm one wire alternator in that **** and yank out all that generator mess!
  22. OLD HEMI
    OLD HEMI
    The lug bolts are usually marked with a L -left R - right on all the old Mopars.
  23. 73RR
    73RR
    ...and another Zombie thread comes to life...
