Best box behind a flathead
Discussion in 'The Hokey Ass Message Board' started by DjNeil, Jul 13, 2013.
  1. DjNeil
    DjNeil
    Are there any six speed boxes that can go behind a late Merc Flattie and is there a custom column that gives you six on the tree.
    If not what would you put behind one for,mainly, motorway miles
    I am open to autos
    Thanks
    Neil
  2. klawockvet
    klawockvet
    You can keep the Ford three speed and column and go with a converted Volvo overdrive mounted in the torque tube. Its electric and can be shifted into overdrive in any gear. Gives you a six speed. Talk to Rich Little in Bakersfield, CA, he converts them and is well thought of. Lots of Model A's are running that set up.
  3. fatkoop
    fatkoop
    Wow! Never heard of that. More info please. Pics if possible and details, which Volvo, how is it mounted, metric to english problems? Is Rich Little a HAMBER by chance?
  4. gkgeiger
    gkgeiger
    Me too!
  5. gasolinescream
    gasolinescream
    Neil have a word with Gavin on R&S. Pretty sure he's using an Amazon 4 speed and O/D box on one of his cars, quite a few do. Cheap and strong and easy to get on our side of the pond.
    Cheers Dan
  6. This is similar to a Gear Vendors setup.
    Here is a link
  7. Saxon
    Saxon
    from MN
    There is also the mitchell overdrive. Doesn't look as natural as the volvo conversion, because it's a square box.
  8. Rocky
    Rocky
    Classified Editor
    If you're using an open driveshaft, a simple borg warner/Tremec T-5, 5 speed is a simple swap. Offenhauser and Speedway Motors make an adapter kit for this swap. I used a '93 chevy S-10 pickup T-5 behind my flathead with an open driveline 1946 ford pickup banjo rear axle. Bolted it all into my old 33 ford pickup. 5th gear is an overdrive gear.
  9. DjNeil
    DjNeil
    Thanks too all.
    checked what mr Gasolinescream recommended looking at and this is a good option
    "Volvo 740 4 speed with overdrive or 5 speed is a very easy conversion and transforms the car especially if you fit a quick change as well to get the right final ratio's"
    Going behind a 276 that could tow an airstream up the side of a mountain
