Chevy C-10 rack and pinion conversion
Discussion in 'The Hokey Ass Message Board' started by MRK, Jul 10, 2013.
  1. MRK
    MRK
    I'm planning on converting a '67 Suburban to rack and pinion using the Unisteer kit that they list for a truck. Does anyone know if Suburban suspension is the same as the truck suspension. Has anyone else done this conversion and what "kit" did you use? Any direction is appreciated.:D
  2. jetnow1
    jetnow1
    from CT
    Should be the same suspension.
  3. 2racer
    2racer
    is it a half ton or 3/4
  4. MRK
    MRK
    It is believed to be a half ton but it has a 6 lug wheel pattern. I take it there is a diffence then??
  5. jetnow1
    jetnow1
    from CT
    6 lug would have been 1/2 ton. 3/4 ton was 8 lug.
  6. MRK
    MRK
    There you go. Now is the suspension on a Suburban the same as a truck?
