Question about 6 volt radio
Discussion in 'The Hokey Ass Message Board' started by sled51merc, Jul 15, 2013.
  1. When rewiring a car to 12 volts I know you can put voltage reducers on gauges and things. But can you put some sort of reducer on a 6 volt radio, and it will work properly or do you have to have it converted to 12 volts?
    Thanks,
    sled
  2. Maybe some help from the early afternoon crowd?
    sled
  3. Marty Strode
    Marty Strode
    I would think a voltage reducer on a radio should work fine. Back in the mid-60's, I converted my 49 Olds to 12 volt. My science cl***es in school taught me, each wet cell in a battery has 2 volts, so I ran a sheet metal screw in the top of the battery exactly in the middle. With my radio wire connected to the screw, my radio worked great.
  4. hotroddon
    hotroddon
  5. I am not switching over to an alternator. Would using a generator be a problem?
    sled
  6. dtracy
    dtracy
    No, not an issue.
    The thing with the radio is the ********. Using a resistor will produce a smooth power source and the radio should operate ok. Test the voltage before you turn the radio on and again during operation.
    Dave.
  7. Thanks fellas! I really appreciate it!
    sled
  8. Aeroman
    Aeroman
    Yes. I ran voltage drops to a '51 Chevy 6V radio but those resistors got HOT. So, make sure you provide a heat sink or simply consider where you put them. You can see them on my firewall:
  9. d2_willys
    d2_willys
    from Kansas
    Adding a resistor inline with the power lead will surely reduce the voltage, but how much is the real question. As your radio pulls more power with the volume up, the resistor will drop the voltage more and more. You would be better off changing the ******** to a 12V type and change the tubes to 12V filament types. After about 1958 most of the AM radios went hybrid, without a ******** and with 12v filaments in the tubes. Early in the 60's the radios went completely solid state.
  10. GeezersP15
    GeezersP15
    from N.E. PA
    The resistor won't start doing it's job until there is current flowing thru it, so checking voltage prior to turning on the radio will show 12V, and as soon as the radio is switched on, a voltage drop thru the resistor will occur, and you should see approximately 6 volts. The exact voltage the radio will receive is dependent on the amount of current the radio requires to operate.
    And you didn't mention it, but are you maintaining the same battery polarity when you switch to 12V? I haven't tried it, but I've read that some tube style radios will operate OK with either polarity. Not sure about that one, but it might be something to follow up on. Good luck!
  11. DaveGeneric
    DaveGeneric
  12. DaveGeneric
    DaveGeneric
    You can put these together yourself for $3-$4, I mounted mine to some heat sinks I salvaged from some junk "boom Boxes". Parts available at your local independent electronics supply or if you have to at Radio Shack.
  13. Rusty O'Toole
    Rusty O'Toole
    6V radio will work on 6V from a resistor or other power source. If it is a tube radio it will draw a lot of power - 5 to 10 amps on the bigger sets.
    Marty's suggestion of a center tap from the battery is excellent, possibly the best and cheapest source of 6V power.
    A 6V radio can be converted to 12V by changing the ******** and tubes.
  14. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    I was thinking about this as well, could be wrong but I don't think the radio will like negative ground. If someone knows for sure I would like to know.
  15. GeezersP15
    GeezersP15
    from N.E. PA
    Since I have not converted a 6V tube/******** radio to 12V, I may be wrong (and often have been), but wouldn't you have to address the increased voltage being applied to the radio's power transformer due to 12V vs. 6V? And the voltage rating of the power supply's filter capacitors, etc? It might work just fine, but I'm skeptical that the conversion would be that simple. Maybe someone else can jump in here and add their opinion and/or expertise.:confused:
  16. d2_willys
    d2_willys
    from Kansas
    You bring up a good point! Let's say you pull 6V square wave from the 6V ********, then step up to 300V. That would be 50 times more of step up in the transformer. Now let's say you get 12V square wave from 12V ******** and feed the same 1:50 transformer. You should get something around 600V. As you brought out, the components, (tubes included) might not be rated for that high voltage. And if the filaments are derived from same transformer, they will also be running at double their rating.
    What could be done is to feed the ******** output to a 2:1 stepdown transformer, then off to the power transformer. That way it is not current sensitive as a dropping resistor is.
  17. Thanks for all the input fellas. I brought my radio into work today and have a guy who is an electrical whiz checking it out. I'll post when he lets me know what he comes up with.
    sled
  18. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    What about changing the polarity?
  19. Rusty O'Toole
    Rusty O'Toole
    The ******** supplies the correct AC high voltage. The tube heaters are 6 or 12 volt. I don't think there is anything polarity sensitive except the ********.
    In any case this is not supposed to be a complete radio repair manual covering the conversion of every radio ever made. I am trying to convey the information that yes, it is possible to change a radio from 6 to 12V. Suggest you find a vintage radio forum or do a web search for specifics. I used to frequent some old radio forums and found the patrons very helpful.
  20. visor
    visor
    from Missouri
  21. gearhead1952
    gearhead1952
    The ******** is just a set of points and the power transformer is like the ignition coil. So yes you would need to change the power transformer if going to 12v. Need to change ******** and tubes and don't forget the dial lights. Tube radios with mechanical ********s will work on positive or negative ground. You can get a solid state ******** in positive or negative ground.
