ford y block question
Discussion in 'The Hokey Ass Message Board' started by riverhead55, Jul 15, 2013.
  1. riverhead55
    riverhead55
    272-292 and 312 engines , is there any visible difference between these engines? or only by the engine number, and where is the number located? ----- thanks Al
  2. Slick111
    Slick111
  3. riverhead55
    riverhead55
  4. lorolr
    lorolr
    Check out john mummert's y block website. He has everything you need to know.
  5. Ole don
    Ole don
    Even the casting numbers are the same for a 292 and 312. You have to look at the back of the crankshaft to tell, or measure bore and stroke. Either one will make a wonderful motor if you make a couple small changes at overhaul time.
  6. R Pope
    R Pope
    They are all 312's till the heads come off........
