Projects "Dust Bowl Special"
Discussion in 'Traditional Hot Rods' started by Bugsy, Mar 16, 2012.
  1. Bugsy
    Bugsy
    from Kansas
    Man...that would be a hell of a howl to hear over the open headered Poncho 400!! I'm not too worried about road noise with them as the roadster makes all kinds of noises anyway. Rattle, bang, pop, pop. I little tire noise would be welcome!!:D
  2. sko_ford
    sko_ford
    They kind of equil things out & its not that loud in the car but I cant sneak up on any think.
    The rossified is fun but the next one will be closer to the dbs
  3. Tim
    Tim
    from KCMO
    I'm anxious to see the new grill!
    Do you plan to drive it to salina or trailer it?
    Posted using My **** Tracey watch and the full custom HAMB app
  4. Bugsy
    Bugsy
    from Kansas
    Tim,
    There will be photos coming soon!! Making some headway on it!!
    I'm sure I'll just trailer over...may be with the Belair Bomber!!!
  5. Tim
    Tim
    from KCMO
    Haha I thought about putting a hitch on the 46, always thought it'd look cool flat towing an old gow job
  6. gwhite
    gwhite
    SUPER MODERATOR
    bump for updates...anxious to see that Whippet radiator & shell!
  7. Bugsy
    Bugsy
    from Kansas
    Ha! you're just anxious to get the '29 radiator off of it!:D
    Wasn't able to do much this weekend but will have pics for you in a couple of days!!!
  8. gwhite
    gwhite
    SUPER MODERATOR
    :D Seriously need pics, going to look killer!
  9. T__N__A
    T__N__A
    get that rad and shell on there yet!?
  10. Bugsy
    Bugsy
    from Kansas
    MAn...I've been bombarded by BS lately!! I had it mounted up once and didn't like the way I had the mounts fabbed up and I'm still working on the right radiator hose reducer method as the Whippet inlet and outlet pipes are way smaller than the A. Then, Iwanted to drive it around on the 4th. of July so i stuck the '29 A radiator back on!! This week....hopefully!!!
  11. NoSurf
    NoSurf
  12. gwhite
    gwhite
    SUPER MODERATOR
  13. T__N__A
    T__N__A
    Here are a few pics for inspiration.......
    Felipe Toltecatl likes this.
  14. Bugsy
    Bugsy
    from Kansas
    You're just jealous because you can't progress as slowly as I do! I'm the president of the SLO-****S, remember??!! Get busy with your new wagon and stop worrying about me!!:D
    T-N-A...thanks for the motivation!! :D
  15. Bugsy
    Bugsy
    from Kansas
    OK...so since I've been stalled out on the Whippet grille and still fighting some issues with the radiator, I decided to do something else yesterday. The kids and I have been driving the roadster quite a bit lately and the split exhaust with straight pipes sounds awesome but to a 5 and 7 year old, it gets loud after a while. I didn't want mufflers and I didn't want to kill the banger goodness, so I decided to put together some pipes with baffles in them. Here's what I did......
    I cut one of the expanded ends off of two, 18" pipes.
    Then I cut some tubing the will be the center section of the baffles...
    Then I ground down a couple of 3/4 inch washers so that they could fit inside the pipes and drilled a couple of holes in them....
    I drilled the two, bigger washers as well and they fit into the back part of the pipe but can't go past where the pipe is expanded. I then drilled holes in the center tubes and welded the washers to each end of the tubes...
    Then I wrapped the tubes in stailess steel mesh and then wrapped the whole deal in a close weave chicken wire....
    Then I drove them into the pipes from the back side where thel wedged into place. The cool thing is that they can be taken out and wrapped more or add in some stainless steel wool if I want.....
    They slipped right onto the existing pipes and only extended them by maybe just over a foot or so and used clamps to secure them. No hangers needed as they aren't long and don't weigh much!
    I think they look great and didn't ruin the look of the exhaust. The best part is that they sound sweet!! It still has a nice pop to it but it really took the edge off of it and you can actually talk in the car now! The kids approve and that's all I care about anyway! The cool thing is that I can take them off and add packing or take them off completely in about 2 minutes and run wide open again! The cops don't stare as much now I noticed when we went to Sonic for a burger last night!
    More to come on the radiator saga.........
  16. -Brent-
    -Brent-
    Awesome job on the mufflers.
  17. Those look great Bugs!
  18. NoSurf
    NoSurf
    Nice. Nothing wrong with a little improvement project for the family! Can't wait to hear it.
  19. Hotrod1959
    Hotrod1959
    Need a video so we can hear it...........
  20. Bugsy
    Bugsy
    from Kansas
    Thanks fellas....I'm pretty happy with them. I still need to mill the maifolds as they aren't 100% true where they meet the block so i do have some exhaust leaks but it's getting there and I think sounds better. With that being said....
    If I can get a hold of a decent camera, I'll do it!!!:D
  21. Bugsy
    Bugsy
    from Kansas
    OK....here's the sneak peek of the Whippet grill shell and radiator. I re did my shell mount today and then just mocked up the radiator. Still have a long way to go but this is what's coming along....
    GWhite....here's your "new radiator that'll be coming your way!!
  22. gwhite
    gwhite
    SUPER MODERATOR
    Wow, this screams 40's gow-job! Nice work!!
  23. sko_ford
    sko_ford
    Oooh boy. I diggit
  24. Gamlebilrokker
    Gamlebilrokker
    from Denmark
    Awesome!
  25. LostHope
    LostHope
    Looking good I like it!
  26. Harvey29
    Harvey29
    from kansas
    Looks awesome Bugsy didn't know you had this. I got mine running now were going to have to go cruizing.
  27. gwhite
    gwhite
    SUPER MODERATOR
    Sweet! I've got your hand pump, oil pressure gauge, and side plate ready! Let me know when - I've got my radiator guy on standby to modify that bad boy to fit my nickel T shell :)
  28. MrModelT
    MrModelT
    Nice work Bugsy.....that was the update i was looking for. It will tide me over for a bit... :D
  29. TBone69
    TBone69
    from NJ
    Looking good!
  30. I think the grille looks great!! Very nice look.
