Quadrajet carbs.. yay or nay?
Discussion in 'The Hokey Ass Message Board' started by jkeckss, Jul 17, 2013.
  1. Dane
    Dane
    from Soquel, CA
    Check the throttle shafts for excessive wear before forking over any cash. They can be fixed but it's mo money...
  2. MATACONCEPTS
    MATACONCEPTS
    Get the Q-Jet adaptor it's like $10 & get a GM HEI Distributor too.
  3. MATACONCEPTS
    MATACONCEPTS
    Come to think of it, you should pick up a Chevy motor to match that carb
  4. Dane
    Dane
    from Soquel, CA
    :D Touché...
  5. ginuine555
    ginuine555
    from louisiana
    It took me a few times rebuilding one to get it right many years ago. After that learning experience i would not hesitate to build them for friends. They were great carbs. It's funny this came up at this time. I was telling my son about my experience of these carbs the other day and that I think I invented new curse words during that time.:)
  6. tfeverfred
    tfeverfred
    When I first built my T, I used one and loved it. It was probably the best carb I have ran, but damn it's ugly. On an open hooded car, it just looks ugly, IMO. But under a hood and a BIG air cleaner, I'd use one in a heart beat.
  7. jkeckss
    jkeckss
    Haha, if I had the patience to do the work, wiring, etc.. LQ9 or LS would be a serious option, but I like the idea of the ford motor in my ford and the 5.0 is light and makes decent power.. this thing will have as little wiring as possible, trying to keep my first build as simple as possible
  8. sunbeam
    sunbeam
    What he said
  9. mtkawboy
    mtkawboy
  10. Larry T
    Larry T
    Ford thought enough of Quadrajets to put them on 429 CJ from the factory (around 1970).
  11. bobkatrods
    bobkatrods
    from aledo tx
    That pretty well sums it up !!!!
  12. carbking
    carbking
    Ford also thought enough of Quadrajets to put them on a host of performance non-smog small blocks for the Australian market.
    Jon.
  13. The problem I have found with picking up these carbs second hand is that as the two front mounting bolts go all the way through the carb including the top, previous owner get carried away with those bolts and over tighten them warping everything causing sealing issues. Have a careful look in this area when looking at a potential purchase.
  14. stimpy
    stimpy
    don't know what your talking about , a q jet has less parts than a Holley and Abf , and no powervalves to blow out or have to change with al***ude or weather changes . you have a va***e controlled primary jet set , and a secondary va***e controlled jet set , and the mixtures are controlled by the needles not a jet and it adjusts quite well to conditions , hardest part is adjusting the secondary airflap ( you must leave the dampner on it ! ) , once you learn how to do it there easy .
    a Holley is a gas toilet compard to a Q jet design , and the best thing is the 350 cfm primarys for milage . if you get bad milage its a adjustment issue ussually the float, the idle adjustment ( timing ), as for fine tuning parts there out there just google it . been to the upper 9 second range at 140 mph in the quarter with a Quadrajet . its a great carb once you learn how to tune it . not like a holley slap it on and let it drip . FORD used them on the COBRA jets vs the Holleys , wonder why ??? ( oops just saw jons post )
  15. stimpy
    stimpy
    Get the Quadrajet Book By Doug Roe , not the one by Ruggles ( which is basically a rewrite) , Roe was a engineer at Rochester , I met Doug several times when I raced , very nice guy and helped me tune mine better , we lost a very knowledgeable person when he p***ed .
  16. falcongeorge
    falcongeorge
    from BC
    Well, that says it all, forget the Q-jet. You should probably get an edelbrock.
  17. 34Larry
    34Larry
    I've had them, they are ok, but some call them quadrapuke's for some reason.
  18. drdoom
    drdoom
    from new jersey
    great carbs. check out Quadrajetparts.com. really good info.and updated parts for todays **** gas
  19. rottenleonard
    rottenleonard
    Just put some throttle shaft bushing in one a few minutes ago, first one in months. We use to do several a day.
    Have to agree with the general census, when people take the time to actually figure out how they work and learn all of the adjustments a light seems to go off in there head and all of a sudden that quadrapuke becomes the best carb designed ever...weird.
  20. hoop98
    hoop98
    from Texas
    As a rookie in 1970 I loved Q-Jets, 2GC's, Monojets, hated 4 jets (12 float adjustments) of course the Buick Q-Jets didn't seem to have 1/2 the problems of Chevies. The worst Q-Jets, which Buick didn't have, were the Carters. Funky looking castings, threads crumbling. IMO
    Of course once you do your first thousand or so nothing should be too hard...well maybe a Motorcraft 4350 ....
  21. saltflats
    saltflats
    from Missouri
    What type of ****** I know the kickdown was talked about. What are you going to do with the car?
  22. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Ive run Q-jets since the 70's. Little tricky to get set up but when there right they work great. I picked up a Edelbrock Q-jet at a swap meet for 15 bucks a while back. It looked like it may have been only run a short while if at all. I located a 66 nailhead Q-jet intake and put it on the 401 in my 50 sedan delivery. Wouldn't have anything else on it now.
  23. Engine man
    Engine man
    from Wisconsin
    Q-jets are very vacuum dependent and could be set up to work well on stock engines. Modified engines with funky camshafts, big valves and low restriction exhaust systems can have inconsistent vacuum. They also work better with a manifold designed to be used with one not so well with an adapter. Tuning is best done on a dyno stand so you have actual data.
  24. Deuces
    Deuces
    Nay!... Quadra-bogs don't do nothing for me..:eek:
  25. 68vette
    68vette
    The quadrajet on my vette has been on there since 1984....has never missed a beat...back in early 70, I put a quadrajet style Holly on there....jerked it off the next day...cut my horsepower and speed in half.
    My 51 ford with 305 had a 72 quadrajet rebuilt and tuned by me and my mechanic and it got 24.6 and 24.4 mpg running 70-80 with NO overdrive...I have one very very simular to that one on my fleetline that is still in progress...it has a 700R...thinking 30 MPG.
    If you want to hear either one, they are on Utube....just type in 1968 corvette sunday drive...or 51 ford custom for sale....its blue....and its sold okay.
  26. Pontiac Slim
    Pontiac Slim
    As stated by many, if set up right the Q-jets can't be beat ! I ran the Holleys for year and seems each year needed a rebuild... Have now 2 Q Jets on a t-ram and haven't touched um in six years. I don't think they look all that great but they work !
    Pontiac Slim
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    One of their advantages is, once they're working the way you want them to, they tend to stay that way. I've had Q-jets that literally sat idle for years on a shelf and, once I put them back on a car, fired up and ran like they did when they were last used. Any time I ever tried that with a Holley, they had a severe incontinence problem.
  28. jkeckss
    jkeckss
    The ****** is a ford AOD, car will be a street machine.. rug er every now and then but highly unlikely I will be doing much for drags etc.. I know AOD needs a lokar kickdown kit to work with carbs, not sure if/how that applies to the quadrajet vs say an edelbrock
  29. stimpy
    stimpy
    apartently you never raced with one , as for the va*** dependency , never a problem with a 320* duration cam , as for manifold never had a problem with a square bore style open plenum ( we used torquer manifolds with a 1" adaptor) and large open headers ( supercomps ) pressure depression works on both holleys and quadrajets , no depression no air flow , and with a q - jet the motor only gets what it needs .. and with low depression you get a need for volume
    as for actual data time slips are my actual data . when I see a waterbrake dyno go down track then I will believe in dyno figures ....
  30. jkeckss
    jkeckss
    I have a pretty mild comp cam, along with the set up I mentioned earlier.. I wanted decent power without a huge gas bill every time I fill.. hence the milder cam and considering the quadrajet.. seems if I can get it tuned properly that might work for me
    Side note: gas here currently is about $4.75 Canadian per gallon ugh
