How to dropped my 46 Ford ?
Discussion in 'The Hokey Ass Message Board' started by bobo1, Jul 14, 2013.
  1. bobo1
    bobo1
    from France
    Hello everybody , I would like to dropped my 46 Coupe Ford , what do you think of this front axle 4" dropped ?
    http://www.speedwaymotors.com/search.html?query=702-2870
    What is the best technique for dropped the rear ? Can I cut the rear cross menber . If you have some pictures , it would be really good ;)
    Can you help me
    Thank's for advance
  2. I would recommend an original dropped Ford axle from Sid. He can answer any of your technical questions, too.
    http://www.droppedaxles.com/
  3. DonMan
    DonMan
    The rear can be dropped with longer leaf spring shackles.
  4. need louvers ?
    need louvers ?
    actually a better way to go on the rear is to de-arch the and re-roll the eyes of the rear spring. Longer shackles, even with the panhard bar Ford was using by that time kinda make the rear of these cars feel "floaty".
  5. bobo1
    bobo1
    from France
    Thank's I'm going to take him a e.mail ;)
    Ok thank you do you have some pictures ?
    Can I modified the rear cross member ?
  6. bobo1
    bobo1
    from France
    Thank's I would like to dropped the rear at 6" , is it possible ?
  7. need louvers ?
    need louvers ?
    Certainly you can modify the crossmember. That was a fairly common trick back in the day with these cars. About the most you can get with what I suggested is about 4" or so.
  8. bobo1
    bobo1
    from France
    Ok thank you ;) I'm going to look
  9. Harvey29
    Harvey29
    from kansas
    square tube makes a good rear cross member and will drop it some, reverse the spring eyes and dearch like mentioned.
  10. bobo1
    bobo1
    from France
    thanh's , very good for the tube , I asked myself exactly the question it is has to believe that mister Henri Ford had planned of dropped his cars :D
    Have you photos of the cup of this tube?
  11. gtopillado
    gtopillado
    He's got the axels for my Dodge Truck at the moment. Came highly recommended to me by a customer. Looking forward to when they return
  12. 68wagon
    68wagon
    Agreed ive reversed the eyes in my 41 and flattened the spring, it sat pretty good but i wanted it lower so I extented the shackles and your right even with a panard bar its still floaty
  13. 68wagon
    68wagon
    This is with the longer shackles and flattened spring and reversed eyes If I remember correctly I think we made the shackles a inch and a half longer
  14. 68wagon
    68wagon
    ImageUploadedByH.A.M.B.1373885444.797300.jpg Top is original
    Middle flattened spring reversed eyes (probably a tool box in the boot lol)
    Bottom extended the shackles flat spring and reversed eyes
    Cheers Scotty
  15. bobo1
    bobo1
    from France
    Very very nice car ;) I would want dropped mine like that
  16. bobo1
    bobo1
    from France
    lovely do you have a front axle 4" dropped ?
  17. bobo1
    bobo1
    from France
    what is the technique to middle flattened spring ?
  18. bobo1
    bobo1
    from France
    I buy to Sid a 4" front axe dropped , when I receive it I going to put it on my car
    and after I see if I need Posie front spring or not :rolleyes:
    Sid is very good seller ;)
  19. need louvers ?
    need louvers ?
    Good! I have seen his work and like it a bunch. You will need to modify your spindle arms to make that dropped axle fit, but do a search here and you will see how it is to be done. It's not too hard to do. Make sure you post some pictures before and after too!
  20. Jalopy Joker
    Jalopy Joker
    on the front you also need to take to account running a rim/tire set up that will clear your fenders for turning. I had a '47 Ford coupe that had reversed eye/de-arched set up that I removed two leafs from and just cleared running 205/65/15 tires any lower and would have rubbed fenders. Tokico shocks, that were for the rear of a early '60 Corvette, did better than any common big name shock to keep the front end from dipping down too much on bumps in the road.
  21. bobo1
    bobo1
    from France
    Ok thank's when I receive it I'm going to post some picture ;)
    Many thank's for your help I shall want to keep on my 16" wheels . I'm going see for Tokico shocks because the French road are not good :rolleyes:
  22. 296 V8
    296 V8
    from Nor~Cal
    Shorter and flatter spring …. easier to undo than a cut up cross member
  23. bobo1
    bobo1
    from France
    thank you but I don't know what is flatter spring :( sorry
    How made you for flatter spring
  24. nxcess
    nxcess
    from Mesa, AZ
    I would be leery of a Speedway axle. They sell a lot of Chinese ****.
    Lowering the rear that much will require C-ing the frame and cutting the trunk for clearance. Maybe even raising the tunnel for drive shaft clearance.
    Just installed a 4" dropped axle I got from SoCal here in AZ in a 36, took out two leaves and the grille only has 1 1/2" clearance ( what the customer wanted). Had to use the dropped arms and still had to modify then and the wishbones, which I also split.
    The rear I installed a 9" Ford with parallel leaves.
  25. bobo1
    bobo1
    from France
    at the final I buy the front axle here : http://www.droppedaxles.com/
    and not to speedway
    I shall want to keep my origin rear axle
    Who can say to me how to make flatter spring ?
  26. nxcess
    nxcess
    from Mesa, AZ
    If there is not a spring shop in you area, you can use a big hammer and a anvil. It just takes a long time.
    'I think with a stock rear end you will have to raise the tunnel. At least at the rear portion.
  27. need louvers ?
    need louvers ?
    That is what is meant by "de-arching" the spring. it literally means taking some of the curve out of the spring itself to make the car sit lower.
  28. bobo1
    bobo1
    from France
    Ok thank you I understand better now :)
  29. bobo1
    bobo1
    from France
    Wednesday , I receive the axle dropped of Sid :D and I put it on my car :)
    The dopped is good now I'm going to dropped the rear of the car ;)
  30. need louvers ?
    need louvers ?
    Awesome man! Good to see stuff going on in other parts of the world.
