Projects V8POP'S V8POP (Anglia)
Discussion in 'The Hokey Ass Message Board' started by v8pop, Jul 19, 2013.
  1. I live just north of Bedford in England. Been looking in on the HAMB for a while now and joined early in the year. My project is a fair way on and I said on my intro I’ll post a continuation tread on here, so here goes…
    Currently building a 1955 Sit Up 'n' Beg Ford Popular (Anglia) it’s an “ol skool” build mostly second hand parts and as much done by me as possible. Front end is the original "I" Beam on a 4 bar set-up converted to Volvo Hubs, Disks with 4 pot Callipers. At the rear is a Volvo 244 GLT axle on a 4 bar set-up. Power comes from a Rover SDi 3500cc V8 (Baby Buick) with a 5 speed manual box. Steels on the front and Alloys on the back. I'm working outside, got no garage so progress is very weather dependant.
    If you fancy some background there’s a 7 year build up thread on the UK NSRA Forum... http://www.nsra.org.uk/newforum/showthread.php?t=19068
    This is how it stood earlier on in the year.
    Been doing odds and ends where I can, Had issues with the steering wheel, I like the original but at 16 inches it’s a wee bit too wide, been using a 12 inch deep dish but I can’t see my gauges… Dilemma is – Fancied a banjo type but 14 inch deep dish !!
    How hard can it be? I’ll make one.
    As usual I start with a CAD drawing of the wheel and a detail of the spokes
    Cut some lengths of 4mm stainless steel rod and off I go.
    Mean while the laser cut parts arrive.
    Start drilling and reaming the spoke holes.
    And before long it’s ***embled ready to weld
    Cleaned it up and tried it for size, looks cool and I can see the gauges, result.
    Happy with that I painted it.
    The good(ish) news is I’ve finished the steering wheel, please remember I’m a Project Manager not a Trimmer, I’ve struggled with this done it three times and this one is the best one, of course this is the first time I’ve attempted something like this so if I was doing another naturally I would do a few bits differently…
    Wrapped it up in pallet wrap.
    And fitted it where it belonged.
    On to the Gas Tank next.
    That's it for now. More when I do more.
    Cheers. Tim W.
  2. 26 T Ford RPU
    26 T Ford RPU
    Nice work Tim. JW
  3. Thanks JW.
  4. Right then, on to the Gas Tank…
    I developed the tank out and got the pieces cut from s**** CR4 at work. I’m making it in two “U” sections and I was able to get the bottom “U” creased and pressed at work, but forgot to take a photo!
    Firstly I sorted out the gauge sender mounting plate
    Then I drilled the baffle plates
    Because I was going to pressure test the tank I made a little air inlet that would be welded to a plate and fitted on the gauge sender mounting.
    Then I cut the 2” diameter filler neck and made a mounting flange for it.
    Then I laid out the hole positions on the top “U” prior to folding.
    Happy with that I pressed it on the workmate.
    Next job was to weld the flange on the filled neck and the fuel pick-up pipe on the boss.
    Then I welded the baffles in, yes I remembered, there’s enough room for the sender. You can just about see the crease in the bottom “U”.
    Then I welded all the component parts into the top “U” and I tacked the two together and started welding it up.
    Because I was using MIG and it’s more prone to pin holes I left a good penetration gap and pulsed back into the hot pool, almost like a gas welding technique.
    And there it is done.
    Next job was to test it...
    Cheers. Tim W.
  5. So… Pressure test time, had my safety valve/indicator rigged up on the filler neck.
    All looked good but by the time I’d drunk my well earned cuppa tea, the glove was flat on the tank. I went round it all with a candle looking for a leak but to no avail, then had a penny drop moment. Grand children can be quite useful.
    Sat it all ways round in Reuben’s paddling pool and eventually found it, on the filler neck, two leaking pin holes.
    I marked them ready for the next time the welder was out and turned my attention to getting the tank fitted in the Pop, I trimmed and folded the inner boot floor where the original tank sat.
    And in she goes, sitting on a couple of axle stands.
    Sorted out the side mounting angles.
    Whipped the tank out and tacked the main mounting angle down the length. And re-welded my leak
    Put the tank back in on some rubber mounting strips, lugged the welder out to the car and tacked the side angles in position, then all back to the shed to finish weld.
    Slipped her back in place, jobs a good un.
    I’ve just got to mark the fixing holes and that’s that tucked away.
    That’s it for now, more when I do more.
    Cheers. Tim W.
  6. scrap metal 48
    scrap metal 48
    Cool car.. Cool build.. Nice skills...
  7. Greg in Jax
    Greg in Jax
    Terrific work. I spent more than 19 years with the Army in Europe and a lot of time in the UK on leave. The skills that rodders there and in Europe tend to have are amazing. Beautiful car!
  8. Mart
    Mart
    I like the pressure test and leak detection technique. Good work!
    Mart.
  9. spinout
    spinout
    from Dallas, TX
    Gonna be great!
  10. captain scarlet
    captain scarlet
    from Detroit
  11. Thanks for the comments guys.
    Cheers. Tim W.
  12. I've got a Dolphin 6 gauge set for the Pop but if you saw the photo of the steering wheel in situ you may have noticed I only have the speedo and the 4 ancillary gauges in the dash. That's because I intend to have a pod mounted Taco, as usual I can't find/afford what I'd like so I've made it...
    I started with a disc, a ring and a strip of 1.2 Zintec.
    Tapped and rolled the band around a bit of thick wall pipe.
    Tacked the disc to one end and the ring to the other.
    Welded it and cleaned it up.
    Now I also added some mounts for the support and made the support but for the life of me I can’t find the photos, so moving on here’s the pod in primer.
    In colour.
    And here it is all ***embled.
    My girls bought me a striping kit last birthday so I thought I would (after a lot of practice) give it a go.
    Cheers. Tim W.
  13. The last bit of inside work I wanted to do was to make a cover for the indicator stalk.
    Drew out what it felt would work on a bit of cereal box
    Looked like it would do the job
    Transferred this to some 18 gauge Zintec to make a top and bottom and rolled a body for each
    Welded and cleaned those.
    And there we have it, a nice little box
    It needs a tube to carry the wiring
    It slips on the column a treat
    Couple of slots for the arm and we’re in business.
    Next is the support for the cable tube and the fixing plates to hold it on.
    All welded in place
    Continued on the next thread...
  14. And on we go again
    Back on with the cover and lid.
    Drill and Tap for the fixings, it will be fitted with ****on heads but I’d only got sets in the shed on Sunday.
    Add Avdel at the back of the cover for the lid.
    That’s it bolted in the Pop (Anglia), all done.
    Next job for me is sorting out that boot lid.
    Cheers. Tim W.
