54 Chevy Bel air frame question
Discussion in 'The Hokey Ass Message Board' started by 32 bowtie, Jul 17, 2013.
  1. 32 bowtie
    32 bowtie
    I am starting a 54 bel air 2 dr project. The car is apart, but labelled and boxed up well. The frame has rust issues with rear body mounts, front braces ( see pics) my question is does anyone repop these parts or know where to get them? I know there are many build posts on. 54's but with out reading all of them I didn't see any mention of frame parts. Thanks for any feedback on the question !!
    ImageUploadedByH.A.M.B.1374063174.028180.jpg ImageUploadedByH.A.M.B.1374063187.886688.jpg ImageUploadedByH.A.M.B.1374063204.413645.jpg
  2. redsdad
    redsdad
    As far as I know, reproduction parts are not available. Ch***is Engineering makes a nice crossmember kit to replace your K member. The struts go to the rear instead of forward.
    That being said, beside the body mount being toast, you have serious structural issues in photo 2 of 3. If I am looking at that right, you took the photo of the body mount that is just to the rear of the front spring perch. Not a good place for thin and holey metal.
    IMHO, get another frame. Find a donor car with a good frame or build one. By the time you get done patching this one up, you will be dollars and time ahead by starting with another one.
  3. hobbyjp
    hobbyjp
    from socal
    Thats pretty sketchy stuff there, If the rest of the frame is even close to what those cross member pieces look like I would start thinking about another original frame, in my opinon the newer frames that guys use usually dont have the right wheel base. Since all the cool kids are running air bags, most of the time the first thing to get removed is that cross member. I would put a wanted add in the cl***ified section and maybe send a pm to Mr. Gambino. Ill bet money hes got one in the corner somewhere. If you have a good welder fab up the pieces they dont have to look original just be the same thickness and function.
  4. fastcar1953
    fastcar1953
    i would look for another frame also. 2and 4 door cars are the same. plus 53 cars. so shouldnt be to hard to find.
  5. RatPin
    RatPin
    Start with solid metal. S**** that frame.
  6. themoose
    themoose
  7. gimpyshotrods
    gimpyshotrods
    Hardtop cars have additional reinforcement in the upper, inner portion of the top-hat, that the others don't have.
  8. yetiskustoms
    yetiskustoms
    To bad you were not closer, I have many frames. I would look for another frame and save yourself the headach
  9. 32 bowtie
    32 bowtie
    Thanks for all your input, it's much appreciated. I'm looking locally to see what's around. The frame other than the spots pictured is solid . Not bad for a northeast car anyway. Into the car for a whole 500.00, so if I have too put a little in its not to bad.
  10. Jbuhl1954
    Jbuhl1954
    I got all my pans from EMS automotive out if Cleveland!! They offer the frame to body mounts also!!!
  11. ems customer service
    i have a few frames for sale
    the ems guy
  12. 54rat210
    54rat210
    Ive heard u cab run a s-10 frame
  13. gimpyshotrods
    gimpyshotrods
    Don't start with that nonsense.
  14. 32 bowtie
    32 bowtie
    How much to buy and ship to 02747 M***achusetts. Do you have any that could be canibalized for the parts I need rear mounts and complete k-member ****** mount? Thanks for the reply I will be in touch I'm sure for a catalog and some panels. Chuck
  15. ems customer service
    shipping you pick it up or arrange
    canibalize why?
  16. 32 bowtie
    32 bowtie
    Ok how much for frame? And what I need are the rear body mounts and the trams mount/ k- member. I didn't know if you may have a less than perfect frame that you would be interested in removing what I need.
  17. redsdad
    redsdad
  18. 32 bowtie
    32 bowtie
  19. Erie Shores
    Erie Shores
    Have any of you guys built a 49-54 bel air and installed a 400hp or less v8 and not reinforce the frame? I was not going to touch my frame but I've had advice a stock frame will twist from hp and torque close to the 400 mark.
