Hot Rods My av8 roadster build
Discussion in 'The Hokey Ass Message Board' started by 28av8, May 8, 2013.
  1. 28av8
    28av8
    Well, I figure after collecting parts and working for about 3 years, it's time to start a build thread.
    I picked up this run down ch***is a few years ago. ImageUploadedByTJJ1368010079.122730.jpg
    I started pulling it apart immediately and got it down to the bare ch***is.
    Started getting some parts together and got most of the front end together. I rearched a factory front spring and got some hydraulic brake parts.
    Then I shipped off to Navy boot camp and a school. And that's how the car sat for about a year until I came home and brought it back to Norfolk with me.
    I re***embled everything in my new garage and went back to work.
    I found an 8ba locally and picked it up. It looked a little rough on the outside but turned out to be a decent motor.
    I got it cleaned up and put back together.
    I did a little more work on the ch***is like modify some f1 shock mounts.
    Then I went on a 9 month deployment.
  2. MN Stumpjumper
    MN Stumpjumper
    Looks like a good start! Thank You for your service!
  3. 28av8
    28av8
    Before I left, I pulled everything back apart and managed to fit my Yukon and a model A ch***is in my 10x20 garage with an engine stand, engine lift, tool boxes, and benches.
    So while I'm out to sea for this whole time, I was able to get some Internet and searched for parts. I was searching for a 28-29 roadster body but kept coming up empty handed. I started looking into Brookville bodies and found a dealer in Richmond. Within a couple of days, I had sent a deposit to Joe Smiths Early Ford and was now just waiting. Waiting to get back home, and waiting for them to build my body.
    I returned home In December to a pile of parts I had ordered.
    I went back to work and got everything set back up the way it was before I left.
    I modified my f1 crossmember and made some engine mounts.
    Everything fit so the engine came back out to have my flywheel and new clutch installed.
    Then the new starter.
    Then everything went back in.
    My tires showed up and I had my wheels powder coated.
    I also sent the heads out to be sandblasted. When I got them back I put the new head studs on and bolted everything together.
  4. 28av8
    28av8
    I put my new Br***works radiator on and had to make a few adjustments for fitment.
    I used my old cowl for mock up so I could start modifying my f1 steering box.
    When my headers got here I realized I needed to shorten it a little more. I went with Sampson block huggers.
    Then after months of waiting, Doug emailed me saying he was picking up the body.
    ImageUploadedByTJJ1368015738.210821.jpg ImageUploadedByTJJ1368015796.392002.jpg
    I finished up some lay minute things and got the car ready for the body.
  5. 28av8
    28av8
    Last weekend was the open house at Joe Smiths. I rented a trailer and made my way up to Richmond.
    We brought it home and dropped it on the frame.
    We pushed her in the garage and that's where she's been sitting for a few days.
    Hopefully I can get over there today and get some work done. I need to make a notch in the firewall about the size on a quarter and it will be all ready to bolt on.
  6. 48fordnut
    48fordnut
    Thanks for what you do. Great looking build.
  7. 1951Biff
    1951Biff
    Very cool man! I love reading these builds, but I hate that you guys all make it look so easy! haha!
    Thanks for sharing your build and most importantly, Thank you for your service!
    Cheers,
    Biff
  8. 48bill
    48bill
    Neat build. Most of all THANK YOU FOR YOUR SERVICE!!!!!!!
  9. 28av8
    28av8
    Thanks for the kind words guys. I'll try to update regularly.
  10. jackandeuces
    jackandeuces
    Chris, looks good will be over to see it....
  11. Pat Pryor
    Pat Pryor
    sweet roadster!
  12. -JoeSmith-
    -JoeSmith-
    Looking Good!
    I had no idea that the ch***is was that far along. It looks like you could drive this to the Open House next year.
  13. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    thanks for your service -great looking roadster build!!
  14. pumpman
    pumpman
    Nice job, you're really moving along quickly, and Thanks for your service.
  15. Rickybop
    Rickybop
    Looking great! The Brookville bodies sure do give a project a leap forward.
    Chris, please tell me...how do you like the body? Have you gone over it and looked at it all pretty closely? Have you found any areas that you're disappointed with at all? I'm considering using a Brookville body on a future project. Many have said that they need "work". I'd like to know if this is true or bs. And if you don't mind, and when you can, would you roughly tally up the total for the body and all the related components such as windshield stanchions, latches, etc? Some have said it can add up to $10,000. Again, I'd really like to know if this is truth or conjecture. Thanks very much.
    Lots of luck with the rest of your build!
  16. OLDTGUY
    OLDTGUY
    Thanks for your service, great looking roadster.
    JJ
  17. Flat-Foot
    Flat-Foot
    from Locust NC
  18. snot275
    snot275
    Cool build!
  19. 28av8
    28av8
    Here's a few progress pics. I removed the smooth cowl and put my original gas tank in.
    I painted the firewall.
    I filled in my key hole for the trunk because I'm switching to a rumble.
    Fitted the windshield.
    We rolled the car outside the other day.
    I need to get the gl*** put in my windshield frame, get a few nuts and bolts, figure out a seat, and tie up some other odds and ends like the ebrake and she will be good to go. Obviously I need to finish the paint, but I can't decide if I want to go with black or blue.
  20. HotRodMicky
    HotRodMicky
    Damm , i love those simple roadsters!!!!!!!
    No need for 32 parts !!!!
    The only thing i dont like, are the headers.....
    They look too street rod to me
  21. 28av8
    28av8
    I can't stand the headers either. As soon as I opened the box I should have just sent them back, but I wanted to start the motor. I haven't finished the exhaust because I plan on changing the headers to something more traditional.
  22. HotRodMicky
    HotRodMicky
    Give jim at red headers a call.
    He will have good headers for you.
  23. 28av8
    28av8
    I originally ordered a set of them but canceled the order because they were going to take too long. I have a set of flanges and a 36 driveshaft that I may put to use.
  24. Hotrodmyk
    Hotrodmyk
    Nice build, great looking roadster.
  25. brady1929
    brady1929
    sweet roadster
  26. Very nice. Inspiring even. What are your plans for the rear - T spring?
    -Pete.
  27. 28av8
    28av8
    I have a t spring but I'm not sure if I'm going to use it. I was able to get it pretty low with the flipped a spring and removing a couple of leafs.
  28. 28av8
    28av8
    Here's a few more pics.
    ImageUploadedByH.A.M.B.1374276363.986781.jpg ImageUploadedByH.A.M.B.1374276372.852249.jpg
    I'm going to roll it outside tomorrow and take some more pics. I still have to finish up the headlights and tail lights, wiring, ebrake handle, seat, and some other small stuff.
  29. peter schmidt
    peter schmidt
    from maryland
  30. 28hiboy
    28hiboy
    from Milton, Fl
    If the world was full of roadster's, it would be a much better place.
