What wheels/tires for 58 country sedan?
Discussion in 'The Hokey Ass Message Board' started by IRMB, Jul 20, 2013.
  1. IRMB
    IRMB
    from SF Bay
    I need to order wheels and tires for my wagon, asap. Mine are totally shot.
    What do you guys reccomend for a cl***y look - maybe a little wider than stock? The spacing in back is pretty darn tight - so I want to make sure I get it right.
    I'm currently running 215/75/14. Thinking of going with 15's. Not sure how wide I can get away with.
    I'm planning on leaving the ride height stock for now and getting Vintique smoothie steel wheels...
  2. id go with chrome reverse that's without seeing the car a pic would help
  3. IRMB
    IRMB
    from SF Bay
  4. id run 15x8 in the back and 15x7 in front either 215 or 225 70 15's those wheels will give the same basic look you have now
  5. IRMB
    IRMB
    from SF Bay
    Thnx! Ordering today. Going with your suggestion- 8's in back, 7's in front.
  6. arkiehotrods
    arkiehotrods
    That car would look great in my driveway.
  7. IRMB
    IRMB
    from SF Bay
    Not sure my neighbors are digging it right now. On jack stands, wheels off, etc. But once I get my Cokers and Steelies it'll be pimpin!
  8. traffic61
    traffic61
    from Owasso, OK
    Some neighbors lack vision. I think you have a great ride going on there.
  9. Gman0046
    Gman0046
    I hope your ordering the Vintiques through Summit not Vintique.
  10. 1951Streamliner
    1951Streamliner
    from Reno, NV
    A wider whitewall would do wonders.
  11. IRMB
    IRMB
    from SF Bay
    What's wrong w vintique?
    Re: whitewalls- Coker cl***ic 2.75"
  12. IRMB
    IRMB
    from SF Bay
    How about rallyamerica instead of vintiques?
  13. Hotrodmyk
    Hotrodmyk
    Check the wheels for runout before you paint or mount the tires. Sometimes they are out of spec.
  14. IRMB
    IRMB
    from SF Bay
    Last question. If I go 7's in front and 8's in back, do I run different tire sizes on each?
  15. Flootiebuell
    Flootiebuell
    Bump.....come on people.....I know there are a lot more opinions on here....
  16. mattrod68
    mattrod68
    since your asking.... i wouldn't do 7's and 8's 6's and 7's would give you an older look. and yes i would run a slightly bigger tire on the back. whatever size you run on the front, up it one for the back.
    maybe a 205/75 and a 225/75 2 3/8 whitewall on the front and 2 3/4 on the back
    bias would look better but im under the impression you want radials
    matt
  17. cody1958
    cody1958
    from wichita ks
    chrome reverses or astros. thin line whitewall.
  18. Since the OP is changing rims I would go with fifteens .... better selection of tires in 15 and mucho cheaper.
  19. IRMB
    IRMB
    from SF Bay
    Thanks y'all! I will post up the results once done. Appreciate the feedback and ideas.
