I believe I have a 1988 302 in my 65 Falcon. The water pump is older and exits on p***enger side. Can anyone suggest what brackets would work for my alternator. Old stock brackets don't seem to line up well. Thanks
I have the same set up on my 302 in my model t. I found some brackets off of a straight 6 in a late 60's fairlane at the local junk yard. I made a shim for between the alt and the head and it bolted right up. Not sure if this helps but I hope so. Posted using the Full Custom H.A.M.B. App!
