Those with Moon tanks.....
Discussion in 'The Hokey Ass Message Board' started by Waddayacare, Mar 1, 2013.
  1. ZAPPER68
    ZAPPER68
    from BC
    Check out my Avatar...mine is used as an expansion tank.
  2. bulletproof1
    bulletproof1
    from tulsa okla
    i use mine for race fuel,it has its own pump and filter,a quick disconnect at the regulator so i can switch from front and rear tanks..3 way toogle controls which pump.
  3. captmullette
    captmullette
    good idea, I might look into that myself......
  4. Sgt._Grumpy
    Sgt._Grumpy
    Mine holds beer!
  5. Mike VV
    Mike VV
    from SoCal
    The Moon tank on my old Anglia was for fuel.
    Mike
  6. mines for gas.
    oh and i made it from an old hobby compressor
  7. ChopTopJimmy
    ChopTopJimmy
    Don't throw it out. Send it to me. I will even pay shipping. I'd be glad to help you get it out of your way. CTJ
  8. Overflow. Real lucky to score an original tank, brackets and spinner cap.
  9. hiboyroadsterboy
    hiboyroadsterboy
    from Mass
    I always wondered the same thing,cause I have a moon tank,and its just for looks,but I didn't think it was cool for just for looks.
  10. thunderplex
    thunderplex
    Just for looks these days...
    This pic taken at the, now defunct, Yellow River Drag Strip staging lanes in 2013.
  11. My lookalike has sand in it for wieght.
  12. Old Ford Coupe
    Old Ford Coupe
    Radiator overflow.
  13. 26hotrod
    26hotrod
    from landis n c
    i have a moon water recovery tank that looks like a small fuel tank. i modified the cap by putting a moon 3 prong knockoff cap on it. it has always done the job and most people think it is a fuel tank. i got mine from Honest Charley @ the Charlotte Auto Fair. they have them all the time..........................
  14. 1971BB427
    1971BB427
    from Oregon
    When this thread started I didn't have a "Moon tank" on my Austin g***er. Now I've got my Falcon g***er on the road, and found a tank at a local swap meet cheap, so I put it on the Falcon and connected it to the radiator as an overflow tank.
    The Austin is so small that a Moon tank would take over the whole frnt end, but the big grille area on the Falcon has tons of space for it!
  15. Veach
    Veach
    That Falcon just keeps getting better each time I see Her
  16. I Drag
    I Drag
    Mine holds methanol and holds up my number.
  17. Atwater Mike
    Atwater Mike
    The ol' 'Nooner' had a 1 gallon Moon tank on the front of his refrigerator white '55 'Hi-Boy'.
    He kept it filled with white Rhine...recycled it by 9:00 A.M. at every run. (than again at 10:00, and quarter to 11...)
  18. II FUNNY
    II FUNNY
    Mine hides my fuel pressure regulators.
    Meltdown Drags 2013 July 19-21
  19. powrshftr
    powrshftr
    I was planning to use mine to hold windshield washer fluid for a water/methanol injection system,but I haven't bought any parts yet so details are still sketchy at best.Figured it would be a good way to keep the motor out of detonation under boost.
    Scott
    Posted using two Dixie cups and a medium length piece of string.
  20. powrshftr
    powrshftr
    Ps: FINALLY picked up that spider valve ***embly at the shipping place...Thanks a bunch Brother!
    Scott
  21. Inland empire hot rods
    from so cal
  22. Ranunculous
    Ranunculous
    Has anyone seen or heard of ethanol etching the aluminum tank innards?
  23. jimmy1931
    jimmy1931
  24. pnevells
    pnevells
    Our look a like holds 2.5 gallons of methanol
  25. Ethanol does not etch aluminum! Ethanol attacks zinc, zinc is one of the metals in the alloy often called "pot metal" which many older carbs are made from. Pot metal or more correctly "White Metal" is often confused with cast aluminum. http://en.wikipedia.org/wiki/Pot_metal
  26. Petejoe
    Petejoe
    from Zoar, Ohio
    I wouldn't consider it a moon but close. 10 gallons of dinosaur piss.
  27. Muttley
    Muttley
    Then you may be interested in this article I found a few years back in one of my old magazines:
  28. Muttley
    Muttley
  29. Muttley
    Muttley
  30. Muttley
    Muttley
